1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: Danfysik system 8000 and 9100 power supplies
From: Donny Domagoj Cosic via Tech-talk <[email protected]>
To: Andrei Guinancio de Carvalho Pereira <[email protected]>
Cc: Ralph Lange via Tech-talk <[email protected]>
Date: Sat, 20 Jan 2024 13:33:53 +0100
Dear Andrei,
"%#B.!" This is what I was looking for, so simple but so effective!!
Thank you for saving me many hours.
Donny Domagoj Cosic
Laboratory for Ion Beam Interactions
Ruđer Bošković Institute
Bijenička cesta 54 | HR-10 000 Zagreb | CROATIA
T: +385 1 4561 041 | @[email protected] | www.irb.hr
Dana 2024-01-19 14:04, Andrei Guinancio de Carvalho Pereira je napisao(la):
Dear Donny,
I have attached db/proto files that we have for a system 8800 power supply.
It deals with the status string. Maybe it works for your case.
Andrei Pereira
Automation Group
Brazilian Center for Research in Energy and Materials
www.cnpem.br
De: Tech-talk <[email protected]> em nome de Donny Domagoj Cosic via Tech-talk <[email protected]>
Enviado: sexta-feira, 19 de janeiro de 2024 09:17
Para: Ralph Lange via Tech-talk <[email protected]>
Assunto: Danfysik system 8000 and 9100 power supplies
Dear all,
I am currently updating our older beam lines which contain the Danfisyk
system 8000 and 9100 power supplies. Does anyone have db/proto files
which they can share with me.
I am having difficulties with the 8000 model. Specifically dividing the
status string which contains characters "!" and "." instead of numbers
which is making it difficult to initialize the On/Off button to the
correct state and other status markers.
Any help would be greatly appreciated.
Donny Domagoj Cosic
T: +385 1 4561 041 | @: [email protected] | www.irb.hr
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Danfysik system 8000 and 9100 power supplies Donny Domagoj Cosic via Tech-talk
RE: Danfysik system 8000 and 9100 power supplies Andrei Guinancio de Carvalho Pereira via Tech-talk
Prev: RE: Problems setting motor position on Galil controller Mark Rivers via Tech-talk
Next: re2c on Windows Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: RE: Danfysik system 8000 and 9100 power supplies Andrei Guinancio de Carvalho Pereira via Tech-talk
