1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: External: IOC Logging
To: "[email protected]" <[email protected]>, "Dr. Simon Friederich" <[email protected]>
Date: Fri, 26 Jan 2024 15:29:44 +0000
I have no experience with syslog-ng, but I can share my experience with another option, elasticsearch. There is no need to use logstash anymore, fielbeat can deal with it, and it's much easier to configure.
On the logserver.
You can add this to the filebeat.yml​
filebeat.inputs:
- type: syslog
  format: auto
  protocol.tcp:
    host: "0.0.0.0:2514"
- type: tcp
  tags: ['epics','ioclog']
  max_message_size: 1MiB
  host: "0.0.0.0:1514"
Ensure the ports are exposed from the container.
In the IOC startup script, setup the log as did for syslog-ng
epicsEnvSet EPICS_IOC_LOG_INET, ${EPICS_IOC_LOG_INET=<YOUR_LOG_SERVER>}
epicsEnvSet EPICS_IOC_LOG_PORT, ${EPICS_IOC_LOG_PORT=1514}
# iocLogPrefix will fail for EPICS 3, but who's using EPICS 3 still???
iocLogPrefix "[${IOC}] "
iocLogInit
errlog "starting ${IOC}"
hope that helps
Niko
From: Tech-talk <[email protected]> on behalf of Dr. Simon Friederich via Tech-talk <[email protected]>
Sent: Friday, January 26, 2024 9:02 AM
To: [email protected] <[email protected]>
Subject: External: IOC Logging
Dear EPICS community,
I am currently investigating what options I have for storing the logs from our IOCs centrally.
I have set up a syslog-ng docker container for testing purposes.
The host server has the IP 10.32.240.32, the docker container has published ports 514 (UDP), 601 (TCP).
For testing purposes, I used a client in the same subnet with the command
    logger -n 10.32.240.32 "my_message"
successfully left a message.
Now I have set the environment variables (on the client) in epics-base/configure/CONFIG_SITE_ENV.
EPICS_IOC_LOG_INET=10.32.240.32
EPICS_IOC_LOG_PORT=601
In a simple test IOC on the client, I say
iocLogInit()
and get the message
epics> log client: connected to log server at '10.32.240.32:601'
I now wanted to test whether I can send a message with errlog:
epics> errlog("my message")
However, after a short time (some seconds) I get:
epics> log client: lost contact with log server at '10.32.240.32:601'
     because "Broken pipe"
Then a short time later the IOC reconnects to the log server.
Have I overlooked something in the configuration?
I am also open to alternatives (e.g. logstash?).
Many thanks and best regards
Simon
Institut für Kernphysik
Kollaboration B | MESA
Johannes Gutenberg-Universität Mainz
Johann-Joachim-Becher-Weg 45
D 55128 Mainz
Tel.: +49 (0)6131 39-23160
E-Mail: [email protected]
IOC Logging Dr. Simon Friederich via Tech-talk
Prev: OpenSSL vulnerability epics Hermann, Raphael P. via Tech-talk
Next: Re: OpenSSL vulnerability epics Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: IOC Logging Dr. Simon Friederich via Tech-talk
Next: Re: IOC Logging NICOLE Remi via Tech-talk
