1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Re: Naming restriction in configure/RELEASE
From: "Hu, Yong via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov (tech-talk at aps.anl.gov)" <tech-talk at aps.anl.gov>
Date: Thu, 1 Feb 2024 15:21:21 +0000
It turns out I had a customized ‘test6App/src/Makefile’ which includes the following lines:
include $(TOP)/configure/CONFIG
# MODULE_CONFIG is auto-generated by ioc_builder.py
include $(TOP)/configure/MODULE_CONFIG
‘MODULE1’ is re-defined in my customized file “include $(TOP)/configure/MODULE_CONFIG”, which overwrites configure/RELEASE. That explains why it failed.
Sorry for the noise.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Hu, Yong via Tech-talk <tech-talk at aps.anl.gov>
Date: Thursday, February 1, 2024 at 8:46 AM
To: tech-talk at aps.anl.gov (tech-talk at aps.anl.gov) <tech-talk at aps.anl.gov>
Subject: Naming restriction in configure/RELEASE
Hello everyone,
I am building an IOC application named ‘test6’ based on the classical command ‘makeBaseApp -t …’.  When I put the following line in ‘test6/configure/RELEASE’ to include an external support module, surprisingly the build failed. Pay attention to the name ‘MODULE1’ which contains a digit.
MODULE1 = /nsls2/users/yhu/modules/elauncherSupport
Here is the error message:
make rebuild
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include    -I/usr/lib/epics/include/compiler/gcc -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include        -MM -MF test6Main.d  ../test6Main.cpp
Creating dbd file test6.dbd
perl -CSD /usr/lib/epics/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I/usr/lib/epics/dbd -o test6.dbd base.dbd asSupport.dbd devIocStats.dbd caPutLog.dbd reccaster.dbd system.dbd elauncherSupport.dbd xxxSupport.dbd dbSubExample.dbd devtest6Version.dbd test6Hello.dbd initTrace.dbd PVAServerRegister.dbd qsrv.dbd
dbdExpand.pl: Can't find file 'elauncherSupport.dbd'
  while reading 'elauncherSupport.dbd' to create 'test6.dbd'
  Your Makefile may need this dependency rule:
    $(COMMON_DIR)/test6.dbd: $(COMMON_DIR)/elauncherSupport.dbd
dbdExpand.pl: Exiting due to errors
If I change ‘MODULE1’ to ‘MODULE’, then it worked as expected. And I see the path ‘-I/nsls2/users/yhu/modules/elauncherSupport/dbd’ is included in ‘perl -CSD /usr/lib/epics/bin/linux-x86_64/dbdExpand.pl’.
make build
perl -CSD /usr/lib/epics/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I/nsls2/users/yhu/modules/elauncherSupport/dbd -I/usr/lib/epics/dbd -o test6.dbd base.dbd asSupport.dbd devIocStats.dbd caPutLog.dbd reccaster.dbd system.dbd elauncherSupport.dbd xxxSupport.dbd dbSubExample.dbd devtest6Version.dbd test6Hello.dbd initTrace.dbd PVAServerRegister.dbd qsrv.dbd
perl -CSD /usr/lib/epics/bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../dbd -I/nsls2/users/yhu/modules/elauncherSupport/dbd -I/usr/lib/epics/dbd    -o test6_registerRecordDeviceDriver.cpp ../O.Common/test6.dbd test6_registerRecordDeviceDriver /nsls2/users/yhu/test6
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include    -I/usr/lib/epics/include/compiler/gcc -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include        -MM -MF test6_registerRecordDeviceDriver.d  test6_registerRecordDeviceDriver.cpp
perl -CSD /usr/lib/epics/bin/linux-x86_64/genVersionHeader.pl   -t ../../.. -N test6VERSION -V "" ../O.Common/test6Version.h
Keeping VCS header ../O.Common/test6Version.h
    test6VERSION = "2cf4d364586c5e06a964-dirty"
Installing dbd file ../../../dbd/xxxSupport.dbd
mkdir ../../../dbd
Installing created dbd file ../../../dbd/test6.dbd
So it seems there is a naming restriction in configure/RELEASE. Is this a bug or a feature? I am using Base-R7.0.5 if the version matters.
Cheers,
Yong
Naming restriction in configure/RELEASE Hu, Yong via Tech-talk
Prev: Naming restriction in configure/RELEASE Hu, Yong via Tech-talk
Next: Re: RMP, REP garbage value Kevin Peterson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Next: Alarm Log Table saleem khan via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
