1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Linux buff/cache memory too high when running Archiver Appliance
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Mon, 5 Feb 2024 08:52:20 +0100
Hello Lin,
Usage of memory for buffers and cache is handled by the Linux kernel, and I have so far not seen a situation where it would do a particularly bad job.
The system making a noticeably "slow" impression is more often related to swapping. The interesting number would be the memory usage of your appliance processes (virtual and resident memory) compared to the installed memory.
Keep in mind that on a Virtual Machine, you have another independent layer of memory usage and swapping in your virtualization engine. If your virtualization is overbooked and running low on memory, guest VMs may be swapped and show degraded behavior without the guest OSs even knowing.
Cheers,
~Ralph
Re: Linux buff/cache memory too high when running Archiver Appliance Michael Davidsaver via Tech-talk
Linux buff/cache memory too high when running Archiver Appliance Wang, Lin via Tech-talk
Prev: RE: Linux buff/cache memory too high when running Archiver Appliance Abdalla Ahmad via Tech-talk
Next: RE: Issue with Stream Device. Timeout only on Reconnect Maximilian Scharpey via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: Re: Linux buff/cache memory too high when running Archiver Appliance Michael Davidsaver via Tech-talk
