1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024
Subject: Re: [EXTERNAL] CSS Phoebus Actions
From: "Hartman, Steven via Tech-talk" <tech-talk at aps.anl.gov>
To: Samuel Manger <samuel.manger at manchester.ac.uk>
Cc: tech-talk <tech-talk at aps.anl.gov>
Date: Thu, 8 Feb 2024 17:16:27 +0000
On Feb 8, 2024, at 8:12 AM, Samuel Manger via Tech-talk <tech-talk at aps.anl.gov> wrote:
I’d like to add an ‘Action’ controlled script that changes the background colour on a ’Spinner’ widget, if the value is changed from the value calculated by a calc field in our software IOC.
That functionality should be straight forward to implement using a Display Builder Rule. The _expression_ can compare the widget’s PV value to the value of the expected value PV and change the background_color property of the widget if they do not match. Using the built-in rules is generally a more portable solution than using a script.
Steven Hartman
hartmansm at ornl.gov
CSS Phoebus Actions Samuel Manger via Tech-talk
Prev: RE: Seeking EPICS Database (.db) File Parser/Generator GAGET Alexis via Tech-talk
Next: New areaDetector releases Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024
Prev: CSS Phoebus Actions Samuel Manger via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
