1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Re: Failed to build archiver appliance
From: Sky Brewer via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Cc: "Shankar, Murali" <mshankar at slac.stanford.edu>
Date: Wed, 14 Feb 2024 08:52:18 +0000
Hi Jörn,
Can you be more specific about the problem? When you start up the archiver do you see any messages in the logs (Catalina.out files or what you specify in the log4j2.xml file default being logs/arch.log and Syslog).
After building the project with ./gradlew the distribution of the project should be found in “build/distributions”. The ui for the mgmt. service is then in the mgmt.war inside the archappl-{version}.tar.gz inside the ui folder.
You should have something like:
ls ui/
appliance.html  css         integration.html  pvdetails.html  storage.html
cacompare.html  help        js                redirect.html
comm            index.html  metrics.html      reports.html
Let me know if you have any other questions or what documentation should be updated to make this clearer.
Thanks
Sky
Re: Failed to build archiver appliance Jörn Dreyer via Tech-talk
Prev: Re: Failed to build archiver appliance Shankar, Murali via Tech-talk
Next: Re: Failed to build archiver appliance Jörn Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
