1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: Epics support for DIGITEL MPCQ Ion Pump Controller and Televac MX 200 Vacuum Controller
From: Abdalla Ahmad via Tech-talk <[email protected]>
To: Mrinal Bera <[email protected]>
Date: Thu, 22 Feb 2024 06:20:51 +0000
Hi Mrinal I am not sure about the mentioned Ion-pump controller, but at SESAME we use the Gamma QPCe Ion-pump controller which is controlled via stream device. I do not have login to Gamma Vacuum website but if the MPCQ model is similar to
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Hi Mrinal
I am not sure about the mentioned Ion-pump controller, but at SESAME we use the Gamma QPCe Ion-pump controller which is controlled via stream device. I do not have login to Gamma Vacuum website but if the MPCQ model is similar to QPCe, I attached the stream device that we use along with a sample template file.
Best Regards,
Abdalla.
From: Tech-talk <[email protected]> On Behalf Of Mrinal Bera via Tech-talk
Sent: Thursday, February 22, 2024 3:50 AM
To: Tech-talk <[email protected]>
Subject: Epics support for DIGITEL MPCQ Ion Pump Controller and Televac MX 200 Vacuum Controller
Did anybody write EPICS support for the following devices? 1) Gamma DIGITEL MPCQ Ion Pump Controller(https: //www. gammavacuum. com/products/digitel-controllers/3335/digitel-mpcq?number=MPCQ1PS1U1SSNI&c=17669) 2) Televac MX200 Vacuum Controller
2) Televac MX200 Vacuum Controller (https://www.frederickscompany.com/products/mx200/)
Mrinal
Mrinal Kanti Bera, PHD
Beamline Scientist and Research Associate Professor
NSF’s ChemMatCARS, Pritzker School of Molecular Engineering,
The University of Chicago
9700 S. Cass Ave Bldg 434D
Argonne, IL-60439
United States
Phone: +1-630-252-0472
Attachment: gamma-ion-pump.template
Description: gamma-ion-pump.template
Attachment: gamma-qpc.proto
Description: gamma-qpc.proto
Epics support for DIGITEL MPCQ Ion Pump Controller and Televac MX 200 Vacuum Controller Mrinal Bera via Tech-talk
Prev: Epics support for DIGITEL MPCQ Ion Pump Controller and Televac MX 200 Vacuum Controller Mrinal Bera via Tech-talk
Next: EPICS Collaboration Meeting 2024 - Update status 조우성(빔운영팀) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: Re: [EXTERNAL] Epics support for DIGITEL MPCQ Ion Pump Controller and Televac MX 200 Vacuum Controller Webb, Brad via Tech-talk
