1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: devAsynFloat64::processCallbackInput process read error
From: Kritsada Kittimanapun via Tech-talk <[email protected]>
Date: Mon, 26 Feb 2024 12:25:27 +0000
Hello, After running the st. cmd, everything looks fine until "iocRun: All initialization complete", then there is an error message. I am not sure if it is from the connection of the device which I have already checked or from the
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Hello,
After running the st.cmd, everything looks fine until "iocRun: All initialization complete", then there is an error message. I am not sure if it is from the connection of the device which I have already checked or from the file setup. Thank you for your advice.
Kritsada
land@raspberrypi:~/epics/keller $ ./start.sh
#!../../bin/linux-x86_64/Keller3040
## You may have to change Keller3040 to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("IOC","iocKeller3040")
epicsEnvSet("TOP","/home/land/epics/keller")
epicsEnvSet("MODULES","/home/land/epics/modules")
epicsEnvSet("ASYN","/home/land/epics/modules/asyn")
epicsEnvSet("MODBUS","/home/land/epics/modules/modbus")
epicsEnvSet("EPICS_BASE","/home/land/epics/base")
dbLoadDatabase("../../dbd/Keller3040.dbd",0,0)
Keller3040_registerRecordDeviceDriver(pdbbase)
## Load record instances
dbLoadRecords("../../db/Keller3040.db","user=mbsdaq")
filename="../../../src/ioc/dbStatic/dbLexRoutines.c" line number=264
No such file or directory dbRead opening file ../../db/Keller3040.db
drvAsynSerialPortConfigure("Keller", "/dev/ttyUSB0", 0, 0, 1)
asynSetOption("Keller", 0, "baud", "9600")
asynSetOption("Keller", 0, "parity", "none")
asynSetOption("Keller", 0, "bits", "8")
asynSetOption("Keller", 0, "stop", "1")
modbusInterposeConfig("Keller", 1, 1000, 0)
# drvModbusAsynConfigure(portName,
#               tcpPortName,
#               slaveAddress,
#               modbusFunction,
#               modbusStartAddress,
#               modbusLength,
#               dataType,
#               pollMsec,
#               plcType);
# Calculated value.
drvModbusAsynConfigure("CH0", "Keller", 1, 3, 0x0000, 2, 0, 0, "Keller")
# Pressure sensor 1.
drvModbusAsynConfigure("P1", "Keller", 1, 3, 0x0002, 2, 0, 0, "Keller")
# Pressure sensor 2.
drvModbusAsynConfigure("P2", "Keller", 1, 3, 0x0004, 2, 0, 0, "Keller")
# Temperature.
drvModbusAsynConfigure("T", "Keller", 1, 3, 0x0006, 2, 0, 0, "Keller")
# Temperature sensor 1.
drvModbusAsynConfigure("TOB1", "Keller", 1, 3, 0x0008, 2, 0, 0, "Keller")
# Temperature sensor 2.
drvModbusAsynConfigure("TOB2", "Keller", 1, 3, 0x000a, 2, 0, 0, "Keller")
# drvModbusAsynConfigure("SNH", "Keller", 250, 3, 0x0200, 2, 0, 100, "Keller")
#asynSetTraceMask "Keller",1,0xff
dbLoadTemplate("Keller.substitutions")
iocInit()
Starting iocInit
## EPICS R3.16.1
## EPICS Base built Jul 30 2018
## Start any sequence programs
#seq sncKeller3040,"user=mbsdaq"
epics> 2024/02/26 10:27:29.299 Keller:CH0 devAsynFloat64::processCallbackInput process read error
2024/02/26 10:27:29.299 Keller:T devAsynFloat64::processCallbackInput process read error
2024/02/26 10:27:29.300 Keller:P1 devAsynFloat64::processCallbackInput process read error
2024/02/26 10:27:29.300 Keller:TOB2 devAsynFloat64::processCallbackInput process read error
2024/02/26 10:27:29.300 Keller:P2 devAsynFloat64::processCallbackInput process read error
2024/02/26 10:27:29.300 Keller:TOB1 devAsynFloat64::processCallbackInput process read error
Re: devAsynFloat64::processCallbackInput process read error Mark Rivers via Tech-talk
Prev: Support Module for Digi-pass devices. Sode, Adedamola (DLSLtd, RAL, LSCI) via Tech-talk
Next: Re: devAsynFloat64::processCallbackInput process read error Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
