This Message Is From an External Sender
This message came from outside your organization.
Hi Michael, I sent a message to both tech-talk and core-talk at 4:31 PM CST yesterday. This is the tech-talk message: https://urldefense.us/v3/__https://epics.anl.gov/tech-talk/2024/msg00292.php__;!!G_uCfscf7eWS!bmNOpw5FmWhW7J7hs8k7hKunvAJL1KAiUVMtLWg60M_Y0F1qm_3OzyqHEmb4XBjxPF1v6SfNStId44T8heqsxHQCaqI$ This is the core-talk message: https://urldefense.us/v3/__https://epics.anl.gov/core-talk/2024/msg00042.php__;!!G_uCfscf7eWS!bmNOpw5FmWhW7J7hs8k7hKunvAJL1KAiUVMtLWg60M_Y0F1qm_3OzyqHEmb4XBjxPF1v6SfNStId44T8heqss-cSrlI$ However, I did not actually then receive the message from tech-talk. And it seems like maybe you did not either? It seems like tech-talk archived it but did not send it? Mark -----Original Message----- From: Michael Davidsaver <mdavidsaver at gmail.com> Sent: Wednesday, February 28, 2024 12:31 PM To: Mark Rivers <rivers at cars.uchicago.edu> Subject: Re: pvAccess assert error Hi Mark, Am I being dense today? I only see a screen capture attached to your original mail. On 2/28/24 10:25, Mark Rivers wrote: > Hi Michael, > > Thanks for the reply. I sent the full stack trace yesterday. > > Mark > > > -----Original Message----- > From: Michael Davidsaver <mdavidsaver at gmail.com> > Sent: Wednesday, February 28, 2024 12:20 PM > To: Mark Rivers <rivers at cars.uchicago.edu> > Cc: tech-talk at aps.anl.gov > Subject: Re: pvAccess assert error > > On 2/26/24 16:37, Mark Rivers via Tech-talk wrote: >> Folks, >> >> I am running a new areaDetector camera. It generates frames that are 4096x3072 pixels, 8-bit. I can collect data from the camera at 150 frames/s using a BitFlow CoaXSpress card with no problems. This is on a Windows PC. >> >> However, when I try to use pvAccess to read the data from the NDPluginPva plugin I get an assert error in pvAccess in my Windows application. The error message is in the attachment. >> >> This happens when I use the ImageJ pvAccess plugin, and also when I use the following Linux command on another machine: >> >> $ pvmonitor 13BF1:Pva1:Image > /dev/null >> >> Any idea what the problem could be? This is base 7.0.7. > > At a guess, maybe another size()==0 situations as with: > > https://urldefense.us/v3/__https://github.com/epics-base/pvDataCPP/issues/50__;!!G_uCfscf7eWS!bmNOpw5FmWhW7J7hs8k7hKunvAJL1KAiUVMtLWg60M_Y0F1qm_3OzyqHEmb4XBjxPF1v6SfNStId44T8heqskRlwRS8$ > > If so, a full stack trace should point at the offending code. >
ANJ, 11 Sep 2024 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
