1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: urldefense.us URLs? (was: New Git mirror for the SNL-Sequencer (code and docs))
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Muir, John Lewis" <[email protected]>, Ralph Lange <[email protected]>
Date: Mon, 4 Mar 2024 17:43:43 +0000
Hi Lewis,
The uldefense URL wrappers are now being added to all messages sent to the [email protected] list from outside of Argonne. I have no control over them, that's due to a recent DOE mandate and not something that the Argonne security people are at liberty to remove AFAIK. Messages from inside Argonne may not have the wrapper added though, thus I am able to post the canonical URLs from my @anl.gov account without them being "decorated". I don't like that discrimination either, but can't easily do anything about it:
The only way to avoid this would be to move the tech-talk list outside of the anl.gov domain, i.e. change the list address and set up replacement infrastructure to manage the list and its archive. The urldefense.us/v3 wrapper is at least nicer than the older v2 ones which other DOE labs have been using for quite a few years, it looks relatively easy to remove with a regexp, or to run it through curl -I to get the original:
ctldev$ curl -I 'https://urldefense.us/v3/__https:/github.com/epics-modules/sequencer/__;!!G_uCfscf7eWS!eE6BmmT8Ri8GapTAzmyfD12LAk9sccR-YQUzobfcJw7GqTEU-BbYLrkuFdpGX4CMuiS_La2TXb2VNWd3dhh53Q$'
HTTP/1.0 200 Connection established
HTTP/1.1 302 Found
Date: Mon, 04 Mar 2024 17:34:32 GMT
Content-Length: 0
Connection: keep-alive
Strict-Transport-Security: max-age=31536000
X-Cache-Status: MISS
X-Robots-Tag: noindex, nofollow
I only just noticed that Ralph's email did not have the somewhat more obnoxious
This Message Is From an External Sender
This message came from outside your organization.
header which was added to all messages at the same time, thus my request to remove that has been accepted and implemented.
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 3/4/24, 10:47 AM, "Tech-talk" <[email protected]> wrote:
On 03/04, Ralph Lange via Tech-talk wrote:
> The "official" Git mirror of the SNL Compiler and Sequencer has found a
> more permanent home under the EPICS-Modules umbrella at
>     https://urldefense.us/v3/__https://github.com/epics-modules/sequencer/__;!!G_uCfscf7eWS!eTS7QVczjxYX8MIiDzYjiJmCxvEeeKu-ZkRiA_dicIRCesT4HJqIPI8KYbHtBm5M0iO27nWOX21u49vSbtd6m0S_tIY$
> with the documentation being available at the canonical place on Pages:
>     https://urldefense.us/v3/__https://epics-modules.github.io/sequencer/__;!!G_uCfscf7eWS!eTS7QVczjxYX8MIiDzYjiJmCxvEeeKu-ZkRiA_dicIRCesT4HJqIPI8KYbHtBm5M0iO27nWOX21u49vSbtd6JaR88-s$
Hi, Ralph!
Are you aware that the URLs you sent are wrapped in a urldefense.us
URL?  When I open a URL, I'd like to go directly to the real URL, not an
intermediary.  In the text/plain part of your email, you can see above
that what would have been a reasonably short and easy-to-read URL has
been changed into a monstrosity.  And for the text/html part, I wouldn't
normally just blindly follow the link (unless on mobile), but it makes
it more of a pain because then I'd have to either copy the text of the
link, or find the actual URL embedded in the urldefense.us URL mess.
Actually, I'd be kind of surprised if you sent URLs wrapped in a
urldefense.us URL since I don't think you're based in the US, right?
So, maybe you didn't do this, but the Tech-Talk mailing list server, or
some server along the way, is doing this automatically?  If so, that's
really annoying, and I certainly would find it frustrating that anything
would be modifying an email that I sent because that would be making
a change without my consent.  (Yes, I'm aware of S/MIME and PGP, but
they're not very widely used.)  If this is the case, maybe Andrew or
someone else at the APS can do something to fix this?
As a test, here's the real URL of the first URL you sent, I'm not
connecting to an ANL SMTP server for submission, and I'm not wrapping it
in a urldefense.us URL, so if it ends up wrapped in one, it wasn't me
who did it:
  https://urldefense.us/v3/__https://github.com/epics-modules/sequencer/__;!!G_uCfscf7eWS!eE6BmmT8Ri8GapTAzmyfD12LAk9sccR-YQUzobfcJw7GqTEU-BbYLrkuFdpGX4CMuiS_La2TXb2VNWd3dhh53Q$
Thanks!
Lewis
Re: urldefense.us URLs? (was: New Git mirror for the SNL-Sequencer (code and docs)) J. Lewis Muir via Tech-talk
Re: urldefense.us URLs? (was: New Git mirror for the SNL-Sequencer (code and docs)) Gerrit Kühn via Tech-talk
New Git mirror for the SNL-Sequencer (code and docs) Ralph Lange via Tech-talk
Prev: urldefense.us URLs? (was: New Git mirror for the SNL-Sequencer (code and docs)) J. Lewis Muir via Tech-talk
Next: Re: urldefense.us URLs? (was: New Git mirror for the SNL-Sequencer (code and docs)) J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
