When I say that PVAccess can for the most part be used just like Channel Access, note that there are still advantages:
Clients are simpler. For Channel Access, it took us some time to figure out how the ideal client reads the DBR_CTRL_.. info once to get all metadata, then subscribes to the plain data type to minimize network traffic. DBE_PROPERTY was added
later to also allow monitoring the meta data. With PVAccess, only changes are transmitted, so you can simply subscribe to the whole data type. The PVA gateway isn’t bogged down by arrays as much as the CA gateway. PVA already has support for IPv6, and there’s
initial work on TLS. Area detector images are more convenient with PVA.
Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Kasemir, Kay via Tech-talk <tech-talk at aps.anl.gov>
Date: Wednesday, March 20, 2024 at 12:43 PM
To: Dave Bracey <dbracey at fnal.gov>, tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: [EXTERNAL] Re: PVXS IOC Philosophy
I’d say the prevalent scenarios would still be IOCs with records, and PVAccess is then used just like Channel Access. That’s why we have normative types which mostly mirror the DBR_.. types, and clients like CS-Studio that can fairly transparently
switch between the two protocols.
With PVAccess you do now have the option to use new types. It allows you to transfer site-specific data over the same protocol, but you can’t expect generic widgets to fully understand your data. That mostly means you need to create both
the server and the client, which you can do in python etc.
The new ‘group’ feature does allow you to create custom types by on combining data from records, but for the client side you’re then again on the hook to create for example a python script to understand that custom data.
So bottom line the goal here should not be that every piece of information now needs to be placed in a newly developed data type with its own custom server and client. On the contrary, the existing record types, the normative types to read/write
them, and generic clients like display managers are meant to fill most of your needs, as was the case with EPICS for the last 30 years.
Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Dave Bracey via Tech-talk <tech-talk at aps.anl.gov>
Date: Wednesday, March 20, 2024 at 12:30 PM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: [EXTERNAL] PVXS IOC Philosophy
Going forward, is the philosophy of PVXS to create PV’s programmatically, per the examples (i.e. https://mdavidsaver.github.io/pvxs/example.html#mailbox-server)
Or, is the idea of creating PV’s by providing record definitions and instances via DBD / DB files still intended to be relevant?
One can create a hybrid IOC (https://mdavidsaver.github.io/pvxs/ioc.html)
and still take in DBD/DB files, but this doesn’t seem to really involve PVXS, at least from the developer’s perspective (other than the fact that QSRV2 makes it work).
As always, I may be completely wrong about any of that, so feel free to let me know.
Dave Bracey – Fermilab AD Instrumentation
- PVXS IOC Philosophy Dave Bracey via Tech-talk
- Re: PVXS IOC Philosophy Kasemir, Kay via Tech-talk
Re: PVXS IOC Philosophy Dave Bracey via Tech-talk
<2024>
<2024>
ANJ, 20 Mar 2024 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
