1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: PVXS IOC Philosophy
From: Dave Bracey via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>, "Kasemir, Kay" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 20 Mar 2024 17:43:25 +0000
First, thank you everyone for the discussion, it is great to get more context filled in as I learn this stuff.
Andrew, to answer your question, I’m primarily after using the tech with the best future, so I was interested in PVXS just from that perspective.  CA is not an issue.
I think my confusion stems mostly from reading the PVXS doc at https://mdavidsaver.github.io/pvxs/ and noticing that it doesn’t mention DB-style “records” anywhere, but it does give examples of building PV’s programmatically at run-time.  This caused me to wonder “is this the new way?”
But from  you guys have been saying here, am I right to think that PVXS is mainly a replacement implementation of pvAccessCPP, etc. and is not intended to change things for the basic IOC developer?
Date: Wednesday, March 20, 2024 at 12:30
 PM
To: Dave Bracey <[email protected]>, Kasemir, Kay <[email protected]>, [email protected] <[email protected]>
[EXTERNAL] – This message is from an external sender
Hi Dave,
When you say PVXS, are you really asking about building IOCs that provide both a Channel Access and PV Access server, or about using the specific PVXS implementation instead of the original pvAccessCPP?
You don't need PVXS to create IOCs that can talk the PVAccess protocol. PVXS started as a reimplementation of the original C++ client and server code for the PVA protocol but using a better internal architecture and written in modern C++. It can communicate over IPv6 now, and future releases will be able to use TLS for much improved security, but those won't change the underlying IOC code significantly.
- Andrew
On 3/20/24, 12:06 PM, "Tech-talk" <[email protected]> wrote:
> I’d say the prevalent scenarios would still be IOCs with records, and PVAccess is then
> used just like Channel Access. That’s why we have normative types which mostly mirror
> the DBR_.. types, and clients like CS-Studio that can fairly transparently switch between
> the two protocols.
I guess I’m unsure what the value of PVXS would be in a scenario like that?  If you are starting from a normal EPICS IOC project, and adding PVXS, what is PVXS doing for you?  You are still defining your PV’s in terms of records in DB files, etc.
I can see that if you are building an IOC for an embedded architecture, the EPICS build system adds value in being able to handle the different toolchains and build products, etc.
However, at the moment I’m looking at making a soft-IOC (i.e. on intel/amd64 linux), and I’m seeing the opportunity to use a simpler (and contemporary) build system and construct PV’s at run-time, rather than use DBD/DB which need to be consumed at build.
I’m wondering if this is a compelling idea at all, or a poor idea?
Date: Wednesday, March 20, 2024 at 11:43
 AM
To: Dave Bracey <[email protected]>, [email protected] <[email protected]>
I’d say the prevalent scenarios would still be IOCs with records, and PVAccess is then used just like Channel Access. That’s why we have normative types which mostly mirror the DBR_.. types, and clients like CS-Studio that can fairly transparently switch between the two protocols.
With PVAccess you do now have the option to use new types. It allows you to transfer site-specific data over the same protocol, but you can’t expect generic widgets to fully understand your data. That mostly means you need to create both the server and the client, which you can do in python etc.
The new ‘group’ feature does allow you to create custom types by on combining data from records, but for the client side you’re then again on the hook to create for example a python script to understand that custom data.
So bottom line the goal here should not be that every piece of information now needs to be placed in a newly developed data type with its own custom server and client. On the contrary, the existing record types, the normative types to read/write them, and generic clients like display managers are meant to fill most of your needs, as was the case with EPICS for the last 30 years.
From: Tech-talk <[email protected]> on behalf of Dave Bracey via Tech-talk <[email protected]>
 PM
To: [email protected] <[email protected]>
Subject: [EXTERNAL] PVXS IOC Philosophy
Going forward, is the philosophy of PVXS to create PV’s programmatically, per the examples (i.e. https://mdavidsaver.github.io/pvxs/example.html#mailbox-server) ?
Or, is the idea of creating PV’s by providing record definitions and instances via DBD / DB files still intended to be relevant?
One can create a hybrid IOC (https://mdavidsaver.github.io/pvxs/ioc.html) and still take in DBD/DB files, but this doesn’t seem to really involve PVXS, at least from the developer’s perspective (other than the fact that QSRV2 makes it work).
As always, I may be completely wrong about any of that, so feel free to let me know.
Dave Bracey – Fermilab AD Instrumentation
Re: PVXS IOC Philosophy Johnson, Andrew N. via Tech-talk
PVXS IOC Philosophy Dave Bracey via Tech-talk
Re: PVXS IOC Philosophy Kasemir, Kay via Tech-talk
Re: PVXS IOC Philosophy Dave Bracey via Tech-talk
Prev: Re: PVXS IOC Philosophy Johnson, Andrew N. via Tech-talk
Next: Streamdevice - record only completes processing every other activation Daykin, Evan via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: Re: PVXS IOC Philosophy Johnson, Andrew N. via Tech-talk
