1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Re: Galil controller with incremental encoder question
From: Mark via Tech-talk <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 22 Mar 2024 22:23:43 +1100
Hi Mark,
I hope you are doing well?  It's good news that the issue is solved.  Sounded like a tricky issue indeed.
In case you're interested in trying the home routines provided, the control settings are located toward the bottom of the motor extras screen.  It's possible to configure the home settings so the current position, except on an active limit, is used as home.  To support the motor extra feature "wrong limit protection", the provided home routine will back off a limit during homing, assuming the home process completes successfully.  If the home process times out (unsuccessful), then the process could complete whilst a limit is still active.  Custom home routines can be delivered to the controller using GalilReplaceHomeCode iocShell function.  The GalilReplaceHomeCode function takes the target axis and a code file name as parameters.  GalilReplaceHomeCode will substitute the macro $(AXIS) found in the specified code file with the axis name specified.  The GalilReplaceHomeCode iocShell function is rarely used, but there are a few production cases.  The axis/motor record homed status can be checked by middleware before driving it.
I highly recommend the Qt EPICS framework as a display technology for use with the Galil driver.  The Galil driver has both MEDM and Qt EPICS screens provided.
The folks at the Australian Synchrotron have developed a fantastic GUI technology for use with EPICS.
https://qtepics.github.io/
The Qt EPICS framework integrates into Qt designer, providing a drag and drop GUI builder, so sites can make their own screens too.
Kind regards,
Mark Clift
On 22/03/2024 12:51 pm, Mark Rivers wrote:
Hi Mark,
I have solved the problem.  It is related to the problem in this tech-talk thread:
https://epics.anl.gov/tech-talk/2024/msg00121.php
My template file did not define ERES, only MRES.  Thus, encoder ratio was infinite during iocInit, which resulted in setEncoderPosition not being called when the motor position was set.  This problem is hard to spot because ERES is later set to MRES in iocInit, so it appears OK.
Based on my previous problem, devMotorAsyn.cpp has been fixed to avoid this issue.  When I updated my motor version to master with that fix the problem is gone.  I could have also fixed it by adding ERES to the template file.
Sorry for the bother.
Sent: Thursday, March 21, 2024 6:07 PM
To: tech-talk at aps.anl.gov; padmoz at tpg.com.au
Hi Mark,
Thanks for the reply, sorry it's taken awhile to get back to this.
I am working on axis C on a Galil 4183 with the D3140 servo amplifier unit installed.
I have attached a screen shot of the motorx_all screen (Galil.png).  I have also attached a screen shot of the galil_motor_extras.adl for this axis (Galil_extras.png).
The axis is configured as Servo with Reverse Quadrature encoder.  (The problem happens with Normal Quadrature as well).
In the motorx_all screen I have set Use Encoder=Yes (UEIP field).  I put the axis in Set mode and type 0 into the VAL field.  VAL, DVAL, and RVAL all set set to 0 as expected.  However, RRBV, RBV, and DRBV do not change, they are the same encoder readback as before I set the position.
  • Ensure dual feedback mode is off with DFx=0.
I have done that.
  • I recommend checking if the value is written to the hardware correctly by using Galil commands DEx=?, DPx=? (where x is the motor in range A-H).
DEC=? returns 0, but DPC=? returns -4000, so the encoder value was not written to the hardware.
Here are the PVs you asked about:
(base) [epics@corvette ~]$ caget 13BMC:Galil7:m73_MTRTYPE_CMD
13BMC:Galil7:m73_MTRTYPE_CMD   Servo
(base) [epics@corvette ~]$ caget 13BMC:Galil7:m73_MTRTYPE_STATUS
13BMC:Galil7:m73_MTRTYPE_STATUS Servo
(base) [epics@corvette ~]$ caget 13BMC:Galil7:m73_MENCTYPE_CMD
13BMC:Galil7:m73_MENCTYPE_CMD  Reverse Quadrature
(base) [epics@corvette ~]$ caget 13BMC:Galil7:m73_MENCTYPE_STATUS
13BMC:Galil7:m73_MENCTYPE_STATUS Reverse Quadrature
(base) [epics@corvette ~]$ caget 13BMC:Galil7:m73_AENCTYPE_CMD
13BMC:Galil7:m73_AENCTYPE_CMD  Normal Quadrature
(base) [epics@corvette ~]$ caget 13BMC:Galil7:m73_AENCTYPE_STATUS
13BMC:Galil7:m73_AENCTYPE_STATUS Normal Quadrature
(base) [epics@corvette ~]$ caget 13BMC:Galil7:m73.ERES
13BMC:Galil7:m73.ERES          0.0001
(base) [epics@corvette ~]$ caget 13BMC:Galil7:m73.MRES
13BMC:Galil7:m73.MRES          0.0001
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Mark Clift via Tech-talk <tech-talk at aps.anl.gov>
Sent: Wednesday, March 13, 2024 9:49 PM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Hi Mark,
On my test system, using a motor with incremental encoder, I can set the position and RRBV updates to the new value.  So I am unable to reproduce the error at this time.
Setting a new motor position involves setting the position on the controller and then reading the position back in the poll cycle.  I recommend checking if the value is written to the hardware correctly by using Galil commands DEx=?, DPx=? (where x is the motor in range A-H).  I'd need to know the motor type to determine which of the above 2 commands to use, so I recommend trying both of the above commands.  At the bottom of the DMC controller screen, is a console where folks can type Galil commands whilst the driver is running.  If the value is not written to hardware I recommend checking GalilAxis::setPosition and GalilAxis::setEncoderPosition methods to find where the write to hardware is failing.
Generally speaking with stepper motors, ERES and MRES are different values and both must be set if an encoder is used.  With servo motors ERES, and MRES are normally the same.
The GalilAxis::poller method reads the motor readback position from hardware, it's a good place to look if the driver isn't reading the value from the hardware correctly.
Ensure dual feedback mode is off with DFx=0.  If DFx=1 then the main and auxiliary encoder registers are swapped.
If no solution is found, could you please report the value of the following records on your system:
$(P)$(M)_MTRTYPE_CMD
$(P)$(M)_MTRTYPE_STATUS
$(P)$(M)_MENCTYPE_CMD
$(P)$(M)_MENCTYPE_STATUS
$(P)$(M)_AENCTYPE_CMD
$(P)$(M)_AENCTYPE_STATUS
$(P)$(M).ERES
$(P)$(M).MRES
And I will try again to reproduce the problem.
Kind regards,
Mark Clift
Virus-free.www.avg.com
Re: Galil controller with incremental encoder question Mark Clift via Tech-talk
Re: Galil controller with incremental encoder question Mark Rivers via Tech-talk
RE: Galil controller with incremental encoder question Mark Rivers via Tech-talk
Prev: RE: Galil controller with incremental encoder question Mark Rivers via Tech-talk
Next: Help to get started with EPICS Schwab, J (bscs) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Next: epics snmp White via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
