1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024
Subject: Re: Creating SNL in loadable library
From: Jure Varlec via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Mon, 25 Mar 2024 10:00:16 +0100
Hello Patrick,
While I'm sure it's possible to create loadable plugins from SNL code using some clever tricks, are you sure it's necessary? I don't see much difference if you simply add several different programs to the IOC. In the end, which program runs is a matter of starting it with the seq command. In other words, choosing which SNL program to run is a matter of configuration by default.
Best,
Jure
On 3/23/24 03:32, Barrett (US), Patrick E via Tech-talk wrote:
Caution: This email originated from outside of Cosylab.
Hello,
I have an IOC which would load different SNL definitions based on a configuration file.  There are some state sets which are the same and some different ones dependent on the configuration.  Has anyone build SNL into libraries which could be dynamically loaded dependent on a configuration, instead of being build into the IOC code directly?
Patrick Barrett
Creating SNL in loadable library Barrett (US), Patrick E via Tech-talk
Prev: RE: Help to get started with EPICS Schwab, J (bscs) via Tech-talk
Next: Re: Help to get started with EPICS Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024
Prev: Creating SNL in loadable library Barrett (US), Patrick E via Tech-talk
Next: RE: [EXTERNAL] Re: Creating SNL in loadable library Barrett (US), Patrick E via Tech-talk
ANJ, 25 Mar 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
