1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: iocStats Restart IOC PV does not work
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Hu, Yong" <[email protected]>, Abdalla Ahmad <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 28 Mar 2024 14:54:26 +0000
Also what version of EPICS Base is this IOC running, and do you see the same problem from other IOCs running the same Base vesion?
- Andrew
On 3/28/24, 9:19 AM, "Tech-talk" <[email protected]> wrote:
Hi Abdalla, is the hanging issue repeatable for your StreamDevice-based IOC? What happens if you simply type “exit” at the EPICS shell? – Yong
From: Tech-talk <[email protected]> on behalf of Abdalla Ahmad via Tech-talk <[email protected]>
Date: Thursday, March 28, 2024 at 5:45
 AM
To: [email protected] <[email protected]>
Subject: iocStats Restart IOC PV does not work
Hi
We have a device controlled via Stream device and the IOC also has devIocStats module configured. When rebooting the IOC by writing 1 to “:SysReset.PROC”, the IOC does not exit, the IOC shell prints the message “IOC Reboot Started” I think and nothing happens, while on most other IOCs it is working well. What could be the issue here?
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME (Synchrotron-light for Experimental Science and Applications in the Middle East)
P.O. Box 7, Allan 19252, Jordan
Tel: +96253511348 , ext. 265
Fax: +96253511423
[email protected]
www.sesame.org.jo
RE: iocStats Restart IOC PV does not work Abdalla Ahmad via Tech-talk
Re: iocStats Restart IOC PV does not work Hu, Yong via Tech-talk
Prev: Re: iocStats Restart IOC PV does not work Hu, Yong via Tech-talk
Next: Re: How can I get a PV from an external server from inside a docker container? Érico Nogueira Rolim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: RE: iocStats Restart IOC PV does not work Abdalla Ahmad via Tech-talk
