1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: enable pvAccess by default
From: William Kirstaedter via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <Tech-talk at aps.anl.gov>
Date: Sun, 31 Mar 2024 22:53:16 +0200
Hello Core Devs,
I would like to know if you have already considered activating pvAccess for softIOCs by default.
I would probably adapt the Makefile template and simply copy the section from the example IOC:
# Link QSRV (pvAccess Server) if available
ifdef EPICS_QSRV_MAJOR_VERSION
    _APPNAME__LIBS += qsrv
    _APPNAME__LIBS += $(EPICS_BASE_PVA_CORE_LIBS)
    _APPNAME__DBD += PVAServerRegister.dbd
    _APPNAME__DBD += qsrv.dbd
endif
Ultimately, this should not affect any old system, as pvAccess is only loaded if it is also present in base?
thanks in advance,
William Kirstaedter
PP&B Computer Support Group
Fritz-Haber-Institut Berlin
Attachment: smime.p7s
Description: Kryptografische S/MIME-Signatur
Re: enable pvAccess by default Érico Nogueira Rolim via Tech-talk
Re: enable pvAccess by default Johnson, Andrew N. via Tech-talk
Re: enable pvAccess by default Michael Davidsaver via Tech-talk
Prev: Re: iocStats Restart IOC PV does not work Michael Davidsaver via Tech-talk
Next: Re: enable pvAccess by default Érico Nogueira Rolim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: Re: PVAccess EPICS environment variables Michael Davidsaver via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
