1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: PyDevice support compilation error
From: Vishnu Patel via Tech-talk <[email protected]>
To: "Tech Talk ([email protected])" <[email protected]>
Date: Wed, 3 Apr 2024 08:23:14 +0000
    I am trying to compile PyDevice python device support on the Ubuntu Core over raspberry pi.  I am using epics base-7.0.1.1 and python 3.5.2
I am getting an error
Installing dbd file ../../dbd/pydev315.dbd
Installing dbd file ../../dbd/pycalcRecord.dbd
Installing generated generic include file ../../include/pycalcRecord.h
mkdir ../../include
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3 -g   -Wall     -I/usr/include/python3.5m -I/usr/include/python3.5m -std=c++11 -O2 -DUSE_TYPED_RSET       -fPIC -g -ggdb -O0 -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I../../../../base-7.0.1.1/include/compiler/gcc -I../../../../base-7.0.1.1/include/os/Linux -I../../../../base-7.0.1.1/include        -c ../asyncexec.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3 -g   -Wall     -I/usr/include/python3.5m -I/usr/include/python3.5m -std=c++11 -O2 -DUSE_TYPED_RSET       -fPIC -g -ggdb -O0 -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I../../../../base-7.0.1.1/include/compiler/gcc -I../../../../base-7.0.1.1/include/os/Linux -I../../../../base-7.0.1.1/include        -c ../epicsdevice.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3 -g   -Wall     -I/usr/include/python3.5m -I/usr/include/python3.5m -std=c++11 -O2 -DUSE_TYPED_RSET       -fPIC -g -ggdb -O0 -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I../../../../base-7.0.1.1/include/compiler/gcc -I../../../../base-7.0.1.1/include/os/Linux -I../../../../base-7.0.1.1/include        -c ../pywrapper.cpp
../pywrapper.cpp:351:67: error: duplicate explicit instantiation of ‘static bool PyWrapper::exec(const string&, bool, T*) [with T = long long int; std::__cxx11::string = std::__cxx11::basic_string<char>]’ [-fpermissive]
 template bool PyWrapper::exec(const std::string&, bool, long long*);
../pywrapper.cpp:352:76: error: duplicate explicit instantiation of ‘static bool PyWrapper::exec(const string&, bool, T*) [with T = long long unsigned int; std::__cxx11::string = std::__cxx11::basic_string<char>]’ [-fpermissive]
 template bool PyWrapper::exec(const std::string&, bool, unsigned long long*);
../../../../base-7.0.1.1/configure/RULES_BUILD:237: recipe for target 'pywrapper.o' failed
make[2]: *** [pywrapper.o] Error 1
make[2]: Leaving directory '/home/vishnu.patel/epics/support/PyDevice/src/O.linux-arm'
../../../base-7.0.1.1/configure/RULES_ARCHS:58: recipe for target 'install.linux-arm' failed
make[1]: *** [install.linux-arm] Error 2
make[1]: Leaving directory '/home/vishnu.patel/epics/support/PyDevice/src'
../../base-7.0.1.1/configure/RULES_DIRS:84: recipe for target 'src.install' failed
make: *** [src.install] Error 2
Is any one have idea?
Thanks
Vishnu
RE: PyDevice support compilation error Pearson, Matthew via Tech-talk
Prev: Re: enable pvAccess by default Ralph Lange via Tech-talk
Next: Re: enable pvAccess by default Han Lee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Deadline Extended: Register for EPICS Summer School 2024! Marcel Bajdel via Tech-talk
Next: RE: PyDevice support compilation error Pearson, Matthew via Tech-talk
