1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: caPutLog breaks monitoring of PV when the same channel is used for putting
From: Érico Nogueira Rolim via Tech-talk <[email protected]>
Date: Fri, 5 Apr 2024 12:35:54 +0000
On 04/04/2024 23:26, Michael Davidsaver wrote:
On Thu, Apr 4, 2024 at 1:28 PM Érico Nogueira Rolim via Tech-talk <[email protected]> wrote:
...It also seems relevant that puts
to these waveforms don't show up in the resulting log.
I saw a similar-ish issue in the caPutLog bugtracker [1], but it was
specifically about QSRV1.
I don't think #22 issue is limited to QSRV1. Rather there is a race condition involving caPutLog and monitoring VAL of waveformRecord and similar.
I see, that makes sense. It would be good to update the commit message in that PR, then. Our affected IOCs don't even link any PVAccess libraries, so I assumed it wouldn't apply to us.
Could you try Simon's proposed fix?
https://github.com/epics-modules/caPutLog/pull/23
It seems to have worked. I will leave a comment in the PR as well.
Thank you for the pointer!
Our versions of things:
In the IOCs and sequencer client:
- epics-base: 7.0.7
- caPutLog: R4.0
- Sequencer: R2-2-9
One of the PyDM interfaces (via conda):
- PyDM: 1.10.3
- pyEPICS: 3.5.0
Other PyDM interface report (via conda):
- PyDM: 1.22.0 or 1.19.1
- pyEPICS: 3.5.1 (from pip)
Cheers,
Érico
[1] https://urldefense.us/v3/__https://github.com/epics-modules/caPutLog/issues/22__;!!G_uCfscf7eWS!ejmmpa48B5Lg-cSSwalI96o2gTPgfS-fdi3OeNW5T6si95vrsnEEIouNzK6cet7e6zcOuYs5JytQ8Xs9sGnrzYO4c64$
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
caPutLog breaks monitoring of PV when the same channel is used for putting Érico Nogueira Rolim via Tech-talk
Re: caPutLog breaks monitoring of PV when the same channel is used for putting Michael Davidsaver via Tech-talk
Prev: Re: caPutLog breaks monitoring of PV when the same channel is used for putting Michael Davidsaver via Tech-talk
Next: Re: caPutLog breaks monitoring of PV when the same channel is used for putting Matthew Newville via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
