1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: RE: Alarm Handler Limitations
From: "Srinivas, Dhruv via Tech-talk" <tech-talk at aps.anl.gov>
To: Paul Sichta <psichta at pppl.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 8 Apr 2024 19:33:17 +0000
Hi Paul,
Thanks for providing this information, what worked for me was making the changes recommended for the server.properties file along with the changes to the settings.ini file.
Sincerely,
Dhruv Srinivas
srinivas1 at llnl.gov
Sent: Saturday, April 6, 2024 5:00 AM
To: Srinivas, Dhruv <srinivas1 at llnl.gov>
Cc: tech-talk at aps.anl.gov
Subject: Re: Alarm Handler Limitations
  Hello Dhruv,
Regarding connecting a remote Phoebus to the alarm server, I also had difficulty getting this to work;  here is what I did:
My alarm server was running kafka, zookeeper, and elasticsearch.  The kafka serves the alarm panel and alarm tree UI on the phoebus, and the elasticsearch is needed for the phoebus alarm logger UI.
On the alarm server machine (epicsalmsrv), the kafka/config/server.properties file had these key lines:
auto.create.topics.enable=false
zookeeper.connect=localhost:2181
listeners=PLAINTEXT://0.0.0.0:9092     (I had a multi-network machine so 0.0.0.0 listens for requests on all ethernet ports, localhost:9092 should work for a single ethernet system)
advertised.listeners=PLAINTEXT://epicsalmsrv:9092
On the alarm server machine,  in  /etc/elasticsearch/elasticsearch.yml:
xpack.security.enabled: false
I recall this setting wasn't present initially, but appears only after the elasticsearch service is started for the first time.
On the alarm server machine, in the alarm_logger.properties file used when starting the alarm-logger.sh, you may need these key settings:
alarm_topics=NSTX-U,Accelerator,CAMAC
es_host=localhost
es_port=9200
es_sniff=false
es_create_templates=true
bootstrap.servers=localhost:9092
On the remote phoebus, these were the key lines for alarms in my settings.ini file (I used three topics) :
#for alarms
org.phoebus.applications.alarm/config_name=NSTX-U
org.phoebus.applications.alarm/config_names=NSTX-U,CAMAC,Accelerator
org.phoebus.applications.alarm/server=epicsalmsrv:9092
# for the alarm logger
#obsolete var --- org.phoebus.applications.alarm.logging.ui/es_host=epicsalmsrv
org.phoebus.applications.alarm.logging.ui/service_uri=http://epicsalmsrv:8080
Also, besides tech-talk I found some good information about these topics on the GIT website, searching the "Issues" .
-ps
On Fri, Apr 5, 2024 at 4:34PM Srinivas, Dhruv via Tech-talk <tech-talk at aps.anl.gov> wrote:
I am currently working on creating an alarm server for our epics IOCs and I’ve been running into a few issues in the process.
To begin with, I’ve noticed that if I add a large number of alarms (~5000 or more), it causes the initial loading process to take a significant amount of time. Often on the order of 30 minutes. I was wondering if this was expected behavior or if there are ways to reduce the load time.
Secondly, I’ve had issues connecting Phoebus to the alarm server. At the moment, I have Phoebus running on one machine and the alarm server running on another one due to various limitations. I also have kafka and zookeeper running on the same machine as the alarm server and have verified that the CLI is functioning. I was hoping someone would know how to connect Phoebus to it, as I’ve been unable to find the port it should connect to.
Sincerely,
Dhruv Srinivas
Alarm Handler Limitations Srinivas, Dhruv via Tech-talk
Re: Alarm Handler Limitations Paul Sichta via Tech-talk
Prev: Re: Use of PUT https://localhost:8181/Olog/logs/multipart REST API for creating log entries with attachments Konrad Gajewski via Tech-talk
Next: Re: Use of PUT https://localhost:8181/Olog/logs/multipart REST API for creating log entries with attachments Konrad Gajewski via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: Re: Alarm Handler Limitations Paul Sichta via Tech-talk
Next: 2024 Spring EPICS Collaboration Meeting : Announcement of abstract submission and training session 조우성(빔운영팀) via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
