1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Publish JSON structure as PVA
From: "Veseli, Sinisa via Tech-talk" <[email protected]>
To: EPICS Tech Talk <[email protected]>, Ralph Lange <[email protected]>
Date: Wed, 10 Apr 2024 17:32:59 +0000
Hi Ralph,
The attached example (converter plus input file used for testing) probably isn't perfect, but it might be useful as a start.
When I run it in my environment it serves object on the 'jsonObject' channel and produces something like this:
$ python jsonToPva.py
structure
    structure codec
        string name
        string parameters
    long compressedSize 60000
    long uncompressedSize 60000
    structure[] dimension
        structure
            long size 300
            long offset 0
            long fullSize 300
            long binning 1
            boolean reverse false
        structure
            long size 200
            long offset 0
            long fullSize 200
            long binning 1
    long uniqueId 246
    structure dataTimeStamp
        long secondsPastEpoch 1712765362
        long nanoseconds 566374540
        long userTag 0
$ pvget -r dataTimeStamp jsonObject
jsonObject structure
        long userTag 0
Sinisa
import json
import pvaccess as pva
class JsonToPvaConverter:
    PVA_DATA_TYPE_MAP = {
        bool  : pva.BOOLEAN,
        int   : pva.LONG,
        float : pva.DOUBLE,
        str   : pva.STRING,
        type(None) : pva.STRING,
    @classmethod
    def getPvaType(cls, value):
        if isinstance(value, dict):
            typeDict = {}
            for k,v in value.items():
                typeDict[k] = cls.getPvaType(v)
            return typeDict
        elif isinstance(value, list):
            if value:
                return [cls.getPvaType(value[0])]
            else:
                return [cls.getPvaType(None)]
        return cls.PVA_DATA_TYPE_MAP[type(value)]
    @classmethod
    def scrubValueDict(cls, valueDict):
        for k, v in list(valueDict.items()):
            if v is None:
                del valueDict[k]
            elif isinstance(v, dict):
               cls. scrubValueDict(v)
        return valueDict
    @classmethod
    def toPvObject(cls, s):
        valueDict = json.loads(s)
        typeDict = cls.getPvaType(valueDict)
        valueDict = cls.scrubValueDict(valueDict)
        pvObject = pva.PvObject(typeDict,valueDict)
        return pvObject
if __name__ == '__main__':
    s = open('t.json').read()
    pvObject = JsonToPvaConverter.toPvObject(s)
    print(pvObject)
    s = pva.PvaServer('jsonObject', pvObject)
    import time
    time.sleep(100)
Siniša Veseli
Scientific Software Engineering & Data Management
Advanced Photon Source
Argonne National Laboratory
(630)252-9182
From: Tech-talk <[email protected]> on behalf of Ralph Lange via Tech-talk <[email protected]>
Sent: Wednesday, April 10, 2024 8:27 AM
Subject: Publish JSON structure as PVA
Dear all,
Does anyone have an application / PVA server that reads a JSON structure (e.g., from file) and publishes it as pvAccess?
Cheers,
~Ralph
Attachment: t.json.gz
Description: t.json.gz
Attachment: jsonToPva.py.gz
Description: jsonToPva.py.gz
Re: Publish JSON structure as PVA Ralph Lange via Tech-talk
Prev: Re: urldefense.us URLs? (was: New Git mirror for the SNL-Sequencer (code and docs)) Johnson, Andrew N. via Tech-talk
Next: Re: Publish JSON structure as PVA Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Publish JSON structure as PVA Ralph Lange via Tech-talk
