1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: ADEuresys: New areaDetector driver for CoaXPress cameras using Euresys frame grabbers
Date: Wed, 10 Apr 2024 23:11:40 +0000
Folks,
R1-0 of ADEuresys is now available.  ADEuresys is a driver for CoaXPress cameras using PCIe frame grabbers from Euresys.
CoaXPress is a high-speed camera interface using multiple coaxial cables.  Each cable can run up to 12.5 Gbits/s, and with 4 parallel cables the total speed is up to 50 Gbits/s.
CoaXPress is based on GenICam, so camera features are controlled the same way as with GigEVision and USBVision cameras.  The ADEuresys driver is derived from ADGenICam.
The driver has been tested on Windows 10 and Linux (CentOS 9 Stream) with the following cameras:
Model
Mikrotron EoSens 2.0MCX12
Adimec Q-12A
ViewWorks VNP604
Pixel dimensions
1920 x 1080
4096 x 3072
14192 x 10640
MegaPixels
2.1
12.6
151.0
CXP version
CXP-12 X4
CXP-6 X4
CXP-6 X4
Frames/s, Mono8
2247
187
6.5
GBytes/s. Mono8
4.66
2.35
1.0
Frames/s, Mono10
1798
152
6.2
GBytes/s. Mono10
7.46
3.83
2.0
Frames/s, Mono12
N.A
N.A
6.2
GBytes/s. Mono12
N.A
N.A
2.0
Note that the Mikrotron camera runs at 2,247 frames per second in Mono8 mode.
Home: https://github.com/areaDetector/ADEuresys
Documentation: https://areadetector.github.io/areaDetector/ADEuresys/ADEuresys.html
Cheers,
Re: ADEuresys: New areaDetector driver for CoaXPress cameras using Euresys frame grabbers Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk
Re: ADEuresys: New areaDetector driver for CoaXPress cameras using Euresys frame grabbers Érico Nogueira Rolim via Tech-talk
Prev: Re: Publish JSON structure as PVA Ralph Lange via Tech-talk
Next: Re: urldefense.us URLs? Chris Johns via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Next: Re: ADEuresys: New areaDetector driver for CoaXPress cameras using Euresys frame grabbers Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk
