1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: streamdevice and input strings
From: Maren Purves via Tech-talk <[email protected]>
To: Zimoch Dirk <[email protected]>
Date: Wed, 17 Apr 2024 00:07:38 -1000
Thank you Dirk.
Still being stuck in the days of drvascii/drvserial we just went to
reading devices that returned a few values by format, like skip until
you get to here, read that, and skip the rest. That may work with asyn
as well if you're not expecting too many values or at too fast a rate.
For us it was/is mostly the weather station.
I'm glad things have moved forward from that even if I am unlikely to
get to that here.
Aloha,
Maren
On Tue, Apr 16, 2024 at 7:26 PM Zimoch Dirk via Tech-talk
<[email protected]> wrote:
> Hello Pierrick,
> StreamDevice uses Separator only for array records (waveform, aai, aao). There, it reads alternating the format and the separator. But the format %s only stops at a space, not at your separator. Thus, the first %s gets the complete string and there is no separator left to read. Here, with redirections to multiple scalar records, the Separator is not used at all. Still the %s consumes as much as it can, that is everything.
> What you need is %[^,] instead of %s (that reads strings up to comma) and explicit commas in between:
> in  "%(\$1:G1Name)[^,],%(\$1:G2Name)[^,], %(\$1:G3Name)[^,],%(\$1:G4Name)[^,]";
> Also, one of the formats (I suggest the last) can be without redirection if the corresponding G*Name record (G4 in this case) is the one which calls this protocol.
> Best regards,
> Dirk
> > Am 17.04.2024 um 01:24 schrieb Pierrick M Hanlet via Tech-talk <[email protected]>:
> > Hi all,
> > I'm on a linux box with AL9.3, base 7.07, and StreamDevice 2.8.24.
> > I have a string input, which the controller gives as: A1,A2,B1,B2.
> > I want to read them individually as separate names, i.e. separate records.
> > My protocol is:
> > get_names {
> >     separator=",";
> >     out "CID";
> >     in  "%(\$1:G1Name)s%(\$1:G2Name)s%(\$1:G3Name)s%(\$1:G4Name)s";
> > although, I've also tried as:
> > get_names {
> >     separator=",";
> >     out "CID";
> >     in "%(\$1:G1Name)s,%(\$1:G2Name)s,%(\$1:G3Name)s,%(\$1:G4Name)s";
> > or as:
> > get_names {
> >     out "CID";
> > Of course, it works perfectly if I have:
> > get_names {
> >     out "CID";
> >     in "%(\$1:G1Name)2c,%(\$1:G2Name)2c,%(\$1:G3Name)2c,%(\$1:G4Name)2c";
> > However, the name can be up to 8 characters long.
> > I don't understand why separator doesn't work as I'm using it.
> > Thank you,
> > Pierrick
> > Pierrick Hanlet
> > Fermi National Accelerator
> > Accelerator Front End Controls
> > +1-630-840-5555 -- lab
> > +1-312-687-4980 -- mobile
> > "Whether you think you can or think you can't, you're right" -- Henry Ford
streamdevice and input strings Pierrick M Hanlet via Tech-talk
Re: streamdevice and input strings Zimoch Dirk via Tech-talk
Prev: Re: streamdevice and input strings Zimoch Dirk via Tech-talk
Next: Re: streamdevice and input strings Pierrick M Hanlet via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
