1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: About the timestamp in py-epicsarchiver lib?
From: "Zhang, Tong via Tech-talk" <[email protected]>
To: "Shen, Guobao" <[email protected]>, Tech-Talk <[email protected]>
Date: Fri, 10 May 2024 16:09:47 +0000
Hi Guobao,
The package “pyarchappl” (https://pypi.org/project/pyarchappl/) supports what you wanted. A CLI tool “pyarchappl-get” is worth to check out, “-h” shows all the options, see the section for timestamps.
Let me know if you have any questions.
Cheers,
Tong
From: Tech-talk <[email protected]> On Behalf Of Shen, Guobao via Tech-talk
Sent: Thursday, May 9, 2024 15:15
To: Tech-Talk <[email protected]>
Subject: About the timestamp in py-epicsarchiver lib?
[EXTERNAL] This email originated from outside of FRIB
I am trying the py-epicsarchiver, and found that it uses the UTC time by default for data retrieving?
Is there a way that I can use local time?
Guobao
About the timestamp in py-epicsarchiver lib? Shen, Guobao via Tech-talk
Prev: Re: Channelfinder Recsync Client: Limit records client side Johnson, Andrew N. via Tech-talk
Next: Output record with TSE=-2 and info(asyn:READBACK, "1") returns <undefined> time. Yann Mandza via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: About the timestamp in py-epicsarchiver lib? Shen, Guobao via Tech-talk
