1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Suspended task in connection with autosave
From: Heinz Junkes via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 31 May 2024 10:21:34 +0200
HI,
I have a small problem on an IOC, probably in connection with autosave?
After iocInit, a message like this appears on the console after 2-3 seconds:
epics> Thread Str (0x75a04c021590) suspended
This does not appear if I do not use autosave.
But autosave seems to work correctly despite this message.
Unfortunately, I don't know how to debug this.
I have inserted an "epicsThreadShowAll" directly after iocInit in st.cmd.
But the task specified in the error message does not even exist in the list?
       reccaster 0x60700ba1bad0  3928911     50       0       OK
  ipToAsciiProxy 0x75a08400fbe0  3928912     10       0       OK
      timerQueue 0x75a084010360  3928913     51       0       OK
    save_restore 0x60700ba1c1c0  3928914     20       0       OK
         CAC-UDP 0x75a084010f20  3928915     52       0       OK
      timerQueue 0x75a04c00f860  3928917     21       0       OK
         CAC-UDP 0x75a04c0202e0  3928918     22       0       OK
    CAC-repeater 0x75a084023b50  3928920     10       0       OK
       CAS-event 0x75a05c005c10  3928922     19       0       OK
      CAS-client 0x75a05c005d40  3928923     20       0       OK
       CAC-event 0x75a04c03e370  3928928     21       0       OK
Danke Heinz
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Prev: Issue with medm's PV Info Message on Ubuntu 24.04 Sang-Woo Kim via Tech-talk
Next: Re: Issue with medm's PV Info Message on Ubuntu 24.04 Soliday, Robert T. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: Issue with medm's PV Info Message on Ubuntu 24.04 Soliday, Robert T. via Tech-talk
Next: ImageJ AD Plugins and PVXS Joshua Einstein-Curtis via Tech-talk
