1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: ImageJ AD Plugins and PVXS
To: Joshua Einstein-Curtis <[email protected]>
Date: Sat, 1 Jun 2024 03:21:12 +0000
Hi Josh,
The text you quote is from the description of an NTMatrix. That is not the normative type used by the areaDetector NDPluginPva plugin or the ImageJ viewer.  They use the NTNDArray normative type, which can have any number of dimensions. AD uses the normal convention for image data which has the first dimension being the number of columns and the second being the number of rows, e.g. a 1920x1200 monitor is [columns, rows].
Sent from my iPhone
On May 31, 2024, at 4:36 PM, Joshua Einstein-Curtis via Tech-talk <[email protected]> wrote:
Hi all,
We're doing some work using PVXS and debugging using the ImageJ AD plugins, and I'm finding something that just doesn't make sense to me. Here's the run down:
For each pvxs::Value, we have two dimensions, as these are array values. Based on the specification in the documentation (https://docs.epics-controls.org/en/latest/pv-access/Normative-Types-Specification.html) I see:
" A dim] of 2 elements describes a matrix, where the first element of dim gives the number of rows, and the second element of dim gives the number columns."
When I set my array up and then send the image to the ImageJ NTNDA_Viewer plugin, I find that dims[0] is the x-axis, while dims[1] is the y-axis, which is the opposite of what I'd expect given the normative type specification.
Just curious if anyone else has run into this, or if I'm missing something obvious.
Josh EC
RadiaSoft
Re: ImageJ AD Plugins and PVXS Joshua Einstein-Curtis via Tech-talk
Prev: ImageJ AD Plugins and PVXS Joshua Einstein-Curtis via Tech-talk
Next: OMS MAXnet whitetiger1123 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: Re: ImageJ AD Plugins and PVXS Joshua Einstein-Curtis via Tech-talk
