1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: OMS MAXnet
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Mon, 3 Jun 2024 09:18:48 +0200
On Mon, 3 Jun 2024 at 06:46, Jörn Dreyer via Tech-talk <[email protected]> wrote:
My recommendation would be to take two small SBC e.g. RaspberryPi and connect each MAXnet controler via a USB2serial adaptor to its own SBC.
Another common option is using a "console server" or 'terminal server". These are COTS boxes that connect multiple serial lines (RS-232, RS-485) to TCP/IP, typically assigning a dedicated port to each serial line.
Many installations use "MOXA boxes" (MOXA NPort 6000 series terminal servers), but there are other vendors with similar products. Such boxes are industrial hardware, combining robustness and high availability with low management and maintenance effort.
On the IOC, the drvAsynSerialPortConfigure is replaced by drvAsynIPPortConfigure. That's typically all that needs to change.
And as that IOC only does network IO, it can easily be moved to a virtualized host, possibly removing the need for your CentOS PC.
Cheers,
~Ralph
Re: OMS MAXnet Peterson, Kevin M. via Tech-talk
OMS MAXnet whitetiger1123 via Tech-talk
Re: OMS MAXnet Jörn Dreyer via Tech-talk
Prev: Re: OMS MAXnet Jörn Dreyer via Tech-talk
Next: Re: ImageJ AD Plugins and PVXS Joshua Einstein-Curtis via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: Re: OMS MAXnet Peterson, Kevin M. via Tech-talk
