1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: asyn master, base 7.0.3 build error from devAsynXXXArray.cpp
To: John Dobbins <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 3 Jun 2024 16:14:51 +0000
Hi John,
  • Switching to base 7.0.6 appears to have fixed that problem.
Good news, I was about to test that asyn still works with gcc 4.8.5.
  • I am trying to build the latest asyn with base-7.0.3 (with a goal of building the latest ADSpinnaker) on linux , Scientific Linux 7.9 , gcc version 4.8.5
Unfortunately, you won’t be able to run ADSpinnaker with gcc 4.8.5.  The ADSpinnaker documentation says this:
As it name implies, ADSpinnaker uses the FLIR/Point Grey Spinnaker library. It runs on Windows, and on Linux versions with gcc 7.5 and higher (e.g. Ubuntu 18, RHEL 8, Centos 8, Debian 10) It does not run on older Linux versions (e.g. Centos 7/RHEL 7) because the FLIR Spinnaker SDK is compiled on Ubuntu 18 and thus requires newer versions of GLIBC and GLIBCXX.
From: Tech-talk <[email protected]> On Behalf Of John Dobbins via Tech-talk
Sent: Monday, June 3, 2024 10:45 AM
To: [email protected]
Subject: Re: asyn master, base 7.0.3 build error from devAsynXXXArray.cpp
Switching to base 7.0.6 appears to have fixed that problem.   John
From: Tech-talk <[email protected]> on behalf of John Dobbins via Tech-talk <[email protected]>
Sent: Monday, June 3, 2024 10:49 AM
To: [email protected] <[email protected]>
Subject: asyn master, base 7.0.3 build error from devAsynXXXArray.cpp
Tech-talkers,
I get the error messages shown below from devAsynXXXArray.cpp
Any help is appreciated. Thanks,
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
www.chess.cornell.edu
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUSE_TYPED_DRVET -DBUILDING_asyn_API   -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DHAVE_DEVINT64  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I../../asyn/drvAsynSerial/os/Linux -I../../asyn/drvAsynSerial/os/default -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/asynPortClient -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/drvPrologixGPIB -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/nfs/chess/epics/det/support_flir/seq-R2-2-9/include   -I/nfs/chess/epics/det/support_flir/calc-R3-7-5/include -I/nfs/chess/epics/det/base-7.0.3/include/compiler/gcc -I/nfs/chess/epics/det/base-7.0.3/include/os/Linux -I/nfs/chess/epics/det/base-7.0.3/include        -c ../../asyn/devEpics/devAsynXXXArray.cpp
In file included from ../../asyn/devEpics/devAsynXXXArray.cpp:18:0:
/nfs/chess/epics/det/base-7.0.3/include/dbCommon.h:47:12: error: using typedef-name ‘dset’ after ‘struct’
     struct dset         *dset;      /* DSET address */
In file included from ../../asyn/devEpics/devAsynXXXArray.cpp:17:0:
/nfs/chess/epics/det/base-7.0.3/include/devSup.h:153:20: note: ‘dset’ has a previous declaration here
 typedef typed_dset dset;
In file included from /nfs/chess/epics/det/base-7.0.3/include/dbAccess.h:19:0,
                 from ../../asyn/devEpics/devAsynXXXArray.cpp:19:
/nfs/chess/epics/det/base-7.0.3/include/dbBase.h:43:9: error: using typedef-name ‘dset’ after ‘struct’
  struct dset *pdset;
In file included from /nfs/chess/epics/det/base-7.0.3/include/dbAccess.h:23:0,
/nfs/chess/epics/det/base-7.0.3/include/dbAccessDefs.h:242:67: error: using typedef-name ‘dset’ after ‘struct’
 epicsShareFunc devSup* dbDSETtoDevSup(dbRecordType *prdes, struct dset *pdset);
In file included from ../../asyn/devEpics/devAsynXXXArray.cpp:27:0:
/nfs/chess/epics/det/base-7.0.3/include/waveformRecord.h:54:12: error: using typedef-name ‘dset’ after ‘struct’
In file included from ../../asyn/devEpics/devAsynXXXArray.cpp:28:0:
/nfs/chess/epics/det/base-7.0.3/include/aaoRecord.h:54:12: error: using typedef-name ‘dset’ after ‘struct’
In file included from ../../asyn/devEpics/devAsynXXXArray.cpp:29:0:
/nfs/chess/epics/det/base-7.0.3/include/aaiRecord.h:54:12: error: using typedef-name ‘dset’ after ‘struct’
make[3]: *** [devAsynXXXArray.o] Error 1
make[3]: Leaving directory `/nfs/chess/epics/det/support_flir/asyn-R4-45/asyn/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/nfs/chess/epics/det/support_flir/asyn-R4-45/asyn'
make[1]: *** [asyn.install] Error 2
make[1]: Leaving directory `/nfs/chess/epics/det/support_flir/asyn-R4-45'
make: *** [/nfs/chess/epics/det/support_flir/asyn-R4-45.install] Error 2
Re: asyn master, base 7.0.3 build error from devAsynXXXArray.cpp John Dobbins via Tech-talk
Prev: Re: asyn master, base 7.0.3 build error from devAsynXXXArray.cpp John Dobbins via Tech-talk
Next: Re: asyn master, base 7.0.3 build error from devAsynXXXArray.cpp John Dobbins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
