1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: firewalld configuration for EPICS?
To: EPICS Tech Talk <[email protected]>
Date: Mon, 3 Jun 2024 23:03:39 +0000
Folks,
I have now empirically answered that question, and it is NOT sufficient to implement the firewall rules documented in the CA Reference Manual.  When I do that, I can only connect to the first IOC I start.
Is there a recipe for configuring the firewall when multiple IOCs are running on that Linux machine?  I can access all IOCs from CA clients running on that same machine, but not from clients running on other machines.
Sent: Monday, June 3, 2024 3:26 PM
Folks,
We would like to start to enable the firewalls on our Linux machines that are running Linux IOCs and clients.
The only “official” documentation I can find is the most recent CA Reference Manual:
https://epics.anl.gov/base/R7-0/8-docs/CAref.html#firewall
And in “How to Configure Channel Access”:
https://epics-controls.org/resources-and-support/documents/howto-documents/configure-channel-access/#Firewalls
Both of these are very terse, and do not explicitly discuss the case of multiple IOCs on a Linux server.
The tech-talk thread I am responding to did not reach a clear conclusion and recommendation.
My configuration is as follows:
  • RHEL 9 servers running multiple IOCs
  • All clients are either on that server or other machines on the same subnet.  Thus, CA searches can simply use broadcasts, and we don’t need to use the IP Tables mechanism.
Is it sufficient to follow these instructions?
Or do the multiple IOCs require additional complexity?
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: Friday, February 28, 2020 4:26 AM
Subject: Re: firewalld configuration for EPICS?
Small note:
On Mon, 24 Feb 2020 at 14:10, Goetz Pfeiffer via Tech-talk <[email protected]> wrote:
Settings for EPICS clients:
  firewall-cmd --add-rich-rule="rule source-port port=5064 protocol=tcp accept"
  firewall-cmd --add-rich-rule="rule source-port port=5064 protocol=udp accept"
  firewall-cmd --add-rich-rule="rule source-port port=5065 protocol=tcp accept"
  firewall-cmd --add-rich-rule="rule source-port port=5065 protocol=udp accept"
Additional settings for EPICS servers:
  firewall-cmd --add-rich-rule="rule port port=5064 protocol=tcp accept"
  firewall-cmd --add-rich-rule="rule port port=5064 protocol=udp accept"
  firewall-cmd --add-rich-rule="rule port port=5065 protocol=tcp accept"
  firewall-cmd --add-rich-rule="rule port port=5065 protocol=udp accept"
Channel Access does not use TCP on the beacon port (aka CA_REPEATER_PORT, ca-2, 5065). Opening it does no harm, but is not needed.
Cheers,
~Ralph
RE: firewalld configuration for EPICS? Freddie Akeroyd - STFC UKRI via Tech-talk
RE: firewalld configuration for EPICS? Abdalla Ahmad via Tech-talk
RE: firewalld configuration for EPICS? Mark Rivers via Tech-talk
Prev: RE: firewalld configuration for EPICS? Mark Rivers via Tech-talk
Next: RE: firewalld configuration for EPICS? Freddie Akeroyd - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
