1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: an IOC based on asynPortDriver
To: [email protected]
Date: Tue, 4 Jun 2024 18:45:43 +0800 (GMT+08:00)
Dear Sir,
I have an IOC based on asynPortDriver.
the st.cmd is:
cd "${TOP}"
dbLoadDatabase "dbd/SHINE.dbd"
SHINE_registerRecordDeviceDriver pdbbase
SHINEConfigure("testAPD", 1000)
dbLoadRecords("db/SHINE.db","P=SHINE-BI:,R=,PORT=testAPD,ADDR=0,TIMEOUT=10000")
#dbLoadRecords("db/asynRecord.db","P=SHINE-BI:,R=,PORT=testAPD,ADDR=0,OMAX=,IMAX=")
########## AUTOSAVE ##########
set_requestfile_path(".")
set_savefile_path("/home/EPICS/","autosave")
save_restoreSet_IncompleteSetsOk(1)
save_restoreSet_DatedBackupFiles(0)
set_pass0_restoreFile("shineioc.sav")
cd "${TOP}/iocBoot/${IOC}"
iocInit
create_monitor_set("shineioc.req",10,"P=SHINE-BI:")
When I start the IOC, all PVs display an error message such as:
devAsynFloat64::initCommon connectDevice failed asynManager:connectDevice port testAPD not found
devAsynInt32::initCommon connectDevice failed asynManager:connectDevice port testAPD not found
Then, when I caget their values, they are all 0.
For example:
record(ai, "$(P)$(R)BPM_X")
   field(DTYP, "asynFloat64")
   field(INP,  "@asyn($(PORT),$(ADDR),$(TIMEOUT))BPM_X")
   field(SCAN, "I/O Intr")
+dbpr, the message is:
AMSG:               ASG :               DESC:               DISA: 0
DISV: 1             NAME: SHINE-BI:BPM_X                    NAMSG:
RVAL: 0             SEVR: INVALID       STAT: UDF           SVAL: 0
TPRO: 0             VAL : 0
Is there a file missing during compilation?
TOP=../..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS BELOW HERE
# Use typed rset structure (see 3.16.1 release notes)
USR_CPPFLAGS += -DUSE_TYPED_RSET
# xxxRecord.h will be created from xxxRecord.dbd
DBDINC += xxxRecord
# Install xxxSupport.dbd into <top>/dbd
DBD += xxxSupport.dbd
# Build an IOC support library
LIBRARY_IOC += SHINESupport
########### ZYM ##############
#LIBRARY_IOC += SHINE
SHINE_SRCS += SHINE.cpp
SHINE_LIBS += asyn
SHINE_LIBS += autosave
SHINE_DBD += asSupport.dbd
# Compile and add code to the support library
SHINESupport_SRCS += xxxRecord.c
SHINESupport_SRCS += devXxxSoft.c
# Link locally-provided code into the support library,
# rather than directly into the IOC application, that
# causes problems on Windows DLL builds
SHINESupport_SRCS += dbSubExample.c
SHINESupport_SRCS += devSHINEVersion.c
SHINESupport_SRCS += SHINEHello.c
SHINESupport_SRCS += initTrace.c
SHINESupport_LIBS += $(EPICS_BASE_IOC_LIBS)
# Auto-generate a header file containing a version string.
# Version comes from the VCS if available, else date+time.
GENVERSION = SHINEVersion.h
# Macro name
GENVERSIONMACRO = SHINEVERSION
# Build the IOC application
PROD_IOC = SHINE
# SHINE.dbd will be created and installed
DBD += SHINE.dbd
# SHINE.dbd will include these files:
SHINE_DBD += base.dbd
SHINE_DBD += xxxSupport.dbd
SHINE_DBD += dbSubExample.dbd
SHINE_DBD += devSHINEVersion.dbd
SHINE_DBD += SHINEHello.dbd
SHINE_DBD += initTrace.dbd
# SHINE_registerRecordDeviceDriver.cpp derives from SHINE.dbd
SHINE_SRCS += SHINE_registerRecordDeviceDriver.cpp
# Build the main IOC entry point where needed
SHINE_SRCS_DEFAULT += SHINEMain.cpp
SHINE_SRCS_vxWorks += -nil-
# Link in the code from our support library
SHINE_LIBS += SHINESupport
SHINE_LIBS += asyn autosave
# To build SNL programs, SNCSEQ must be defined
# in the <top>/configure/RELEASE file
ifneq ($(SNCSEQ),)
    # Build sncExample into SHINESupport
    sncExample_SNCFLAGS += +r
    SHINE_DBD += sncExample.dbd
    # A .stt sequence program is *not* pre-processed:
    SHINESupport_SRCS += sncExample.stt
    SHINESupport_LIBS += seq pv
    SHINE_LIBS += seq pv
    # Build sncProgram as a standalone program
    PROD_HOST += sncProgram
    sncProgram_SNCFLAGS += +m
    # A .st sequence program *is* pre-processed:
    sncProgram_SRCS += sncProgram.st
    sncProgram_LIBS += seq pv
    sncProgram_LIBS += $(EPICS_BASE_HOST_LIBS)
endif
# Link QSRV (pvAccess Server) if available
ifdef EPICS_QSRV_MAJOR_VERSION
    SHINE_LIBS += qsrv
    SHINE_LIBS += $(EPICS_BASE_PVA_CORE_LIBS)
    SHINE_DBD += PVAServerRegister.dbd
    SHINE_DBD += qsrv.dbd
endif
# Finally link IOC to the EPICS Base libraries
SHINE_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
#  ADD EXTRA GNUMAKE RULES BELOW HERE
# Explicit dependency needed for generated header file
devSHINEVersion$(DEP): $(COMMON_DIR)/$(GENVERSION)
Best regards,
Yimei Zhou
Re: an IOC based on asynPortDriver Mark Rivers via Tech-talk
Prev: RE: firewalld configuration for EPICS? Abdalla Ahmad via Tech-talk
Next: Re: Required Perl modules? John Dobbins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Reg. Motorola MVME162PA-344 Bombay Engineering via Tech-talk
Next: Re: an IOC based on asynPortDriver Mark Rivers via Tech-talk
