1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: ca/pva access doesnt handle DNS adressing correctly?
From: Andrea michelotti via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 5 Jun 2024 09:20:05 +0200
Hi all,
I'm new to EPICS, but I spent a lot of time last week trying to understand a strange behavior with cagateway. When initialized with EPICS_CA_ADDR_LIST=<myiocdnsname0> <myiocdnsname1> ..., it works fine as long as <myiocdnsname0> retains its IP address at (cagateway) startup. However, if the IP changes for any reason, you get disconnected from that IOC permanently, regardless of any timeout settings in cagateway.
Initially, I thought this was a significant bug in cagateway, but after discussing it with Ralph and Michael, I learned that the issue could lies in the EPICS base channel access library. It retrieves the IP address of the specified DNS nodes at startup and does not perform any further DNS interactions. The only way to update the IP is to restart the service (either cagateway or the camonitor client).
In short, it seems in CA/PVA there's an assumption that one DNS name equals one permanent, immutable IP. This is only partially true in DNS adressing context and does not hold in modern contexts like Kubernetes.
I've posted this as a bug in both the cagateway and epicsbase projects, but I'm not sure if the community sees it the same way. What do you think?
Thank you in advance,
Andrea
dr. Andrea Michelotti
Head of Control Systems Service
INFN - Laboratori Nazionali di Frascati
Accelerator Division,
Bldg.2, Room 120
Via Enrico Fermi, 40
00044 Frascati (RM)
e-mail:   [email protected]
office:   (+39) 06.9403.2272
mobile:   (+39) 06.9403.8203
fax   :   (+39) 06.9403.2256
Teams :   [email protected]
LinkedIn: https://urldefense.us/v3/__http://it.linkedin.com/in/michelotti__;!!G_uCfscf7eWS!crKuhF56dEWTjk1Kjy6siQPmf8Uvqp4_8uTlj4jVwdTf7IQT5dFi6shvCpnzLkgQo3g364ulSdKXNMPegzid_D-WuWon0f3A$
Prev: Re: an IOC based on asynPortDriver Mark Rivers via Tech-talk
Next: Re: Required Perl modules? John Dobbins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: ADSpinnaker, BlackfkyS 161S7M Not enough available memory to allocate buffers for streaming John Dobbins via Tech-talk
