1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: Required Perl modules?
To: John Dobbins <[email protected]>
Date: Wed, 5 Jun 2024 18:38:31 +0000
Hi John,
It would basically be the same as other USB cameras.  For example:
$ more st.cmd.PGR_GS3_U3_51S5M
< envPaths
errlogInit(20000)
dbLoadDatabase("$(TOP)/dbd/spinnakerApp.dbd")
spinnakerApp_registerRecordDeviceDriver(pdbbase)
# Use this line for a specific camera by serial number, in this case a BlackFlyS GigE
epicsEnvSet("CAMERA_ID", "15337483")
epicsEnvSet("GENICAM_DB_FILE", "$(ADGENICAM)/db/PGR_GS3_U3_51S5M.template")
< st.cmd.base
You just need to change the serial number to that for your specific camera and the .template file to that for your camera model.
Sent: Wednesday, June 5, 2024 1:25 PM
Cc: [email protected]
Subject: Re: Required Perl modules?
Is there an example st.cmd file for a BlackFlyS USB camera?
iocBoot/iocSpinnaker/start_epics  references st.cmd.bflys_usb3
but that doesn't exist.
John
Sent: Wednesday, June 5, 2024 9:32 AM
Cc: [email protected] <[email protected]>
My bad.  I incorrectly cloned ADGenICam into ADGeniCam.  John
Sent: Wednesday, June 5, 2024 9:28 AM
To: Mark Rivers <[email protected]>; John Dobbins <[email protected]>
I should note the running make in ADGeniCam works but running make in support_flir stir produces the same error.
John
From: Tech-talk <[email protected]> on behalf of John Dobbins via Tech-talk <[email protected]>
Sent: Wednesday, June 5, 2024 9:22 AM
Mark,
Using base-7.0.6, areaDetector-R3-13,  and your list of prerequisites below I have gotten as far as ADGeniCam (in my effort to get to ADSpinnaker).
Stuck at:
make[4]: Entering directory '/nfs/chess/epics/det/support_flir/areaDetector-R3-13/ADCore/ADApp/op'
make[4]: Nothing to be done for 'install'.
make[4]: Leaving directory '/nfs/chess/epics/det/support_flir/areaDetector-R3-13/ADCore/ADApp/op'
make[3]: Leaving directory '/nfs/chess/epics/det/support_flir/areaDetector-R3-13/ADCore/ADApp'
make[2]: Leaving directory '/nfs/chess/epics/det/support_flir/areaDetector-R3-13/ADCore'
make -C /nfs/chess/epics/det/support_flir/areaDetector-R3-13/ADGenICam install
make[2]: Entering directory '/nfs/chess/epics/det/support_flir/areaDetector-R3-13/ADGenICam'
make[2]: *** No rule to make target 'install'.  Stop.
make[2]: Leaving directory '/nfs/chess/epics/det/support_flir/areaDetector-R3-13/ADGenICam'
make[1]: *** [/nfs/chess/epics/det/base-7.0.6/configure/RULES_DIRS:85: /nfs/chess/epics/det/support_flir/areaDetector-R3-13/ADGenICam.install] Error 2
make[1]: Leaving directory '/nfs/chess/epics/det/support_flir/areaDetector-R3-13'
make: *** [/nfs/chess/epics/det/base-7.0.6/configure/RULES_DIRS:85: /nfs/chess/epics/det/support_flir/areaDetector-R3-13.install] Error 2
jad22@lnx209 $ gedit /nfs/chess/epics/det/base-7.0.6/configure/RULES_DIRS &
John
Sent: Monday, June 3, 2024 9:31 PM
Hi John,
This is what I have found necessary for our installations.
In order to build EPICS base and the synApps support tree, including our local application, on RHEL 9  I needed to install the following additional packages:
  • telnet
  • libusb-devel
  • perl-FindBin
  • perl-ExtUtils-Command
  • re2c
  • rpcgen
  • libtirpc-devel
  • boost-devel
  • readline-devel
  • libssh2-devel
  • zeromq-devel
  • libraw1394-devel
areaDetector needs aravis to be installed.  aravis requires installing
Measurement Computing support requires installing their uldaq library, which is built from source.  That can be built and installed as follows:
./configure
make
sudo make install
Sent from my iPhone
On Jun 3, 2024, at 7:20 PM, John Dobbins via Tech-talk <[email protected]> wrote:
All,
I am building EPICS support on a new (for me) version of linux, Alma 9.  Previous work on Scientific Linux 7.
I got to calc-R3-7-5 and I run into a PERL related error.
perl -CSD -MExtUtils::Command -e cat ../calcSupport_LOCAL.dbd ../calcSupport_withSSCAN.dbd ../calcSupport_withSNCSEQ.dbd > calcSupport.dbd
Can't locate ExtUtils/Command.pm in @INC (you may need to install the ExtUtils::Command module) (@INC contains: /usr/local/lib64/perl5/5.32 /usr/local/share/perl5/5.32 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5).
BEGIN failed--compilation aborted.
A quick look at the Alma 9 PERL install shows ExtUtils missing.
I see that the Alma 9 PERL install appears to be missing other modules I see in the SL7 PERL install.
I am wondering if there is a list PERL modules needed for EPICS build?  (as opposed to discovery by trial)
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
Required Perl modules? John Dobbins via Tech-talk
Re: Required Perl modules? Mark Rivers via Tech-talk
Re: Required Perl modules? John Dobbins via Tech-talk
Prev: Re: Required Perl modules? John Dobbins via Tech-talk
Next: RE: Required Perl modules? Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: RE: Required Perl modules? Mark Rivers via Tech-talk
Next: Reg. Motorola MVME162PA-344 Bombay Engineering via Tech-talk
