1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: ADSpinnaker, BlackfkyS 161S7M Not enough available memory to allocate buffers for streaming
From: John Dobbins via Tech-talk <[email protected]>
To: "[email protected]" <[email protected]>, Mark Rivers <[email protected]>, John Dobbins <[email protected]>
Date: Sun, 9 Jun 2024 21:02:47 +0000
I tracked this down to DeviceLinkThroughputLimit  (found on BFS USB 161S7 Feature Screen #1) which seems to sometimes revert to a smaller number when the camera is power cycled.
John
From: Tech-talk <[email protected]> on behalf of John Dobbins via Tech-talk <[email protected]>
Sent: Thursday, June 6, 2024 3:51 PM
To: [email protected] <[email protected]>; Mark Rivers <[email protected]>
Mark,
I did some more poking around, plugging the camera back into a Windows machine and using SpinView and saw that there is some sequence of events which causes the camera to have the frame rate limited to 2.66 Hz.
By unplugging/replugging it and toggling various settings I got it back to full frame rate on Windows.
I then removed it from Windows and plugged it into the linux box and I am now getting 21 Hz with the IOC !!!
So there seems to be something needing more investigating.
John
Sent: Thursday, June 6, 2024 1:35 PM
After configuring USB-FS memory I now have the camera running.
One thing I don't understand is that I can't set the Acquire period below 0.375 seconds, i.e a frame rate of 2.66 Hz.
Is there a bandwidth limit somewhere?
John
Sent: Thursday, June 6, 2024 11:59 AM
To: John Dobbins <[email protected]>
Subject: RE: ADSpinnaker, BlackfkyS 161S7M Not enough available memory to allocate buffers for streaming
https://www.flir.com/support-center/iis/machine-vision/application-note/understanding-usbfs-on-linux/
From: Tech-talk <[email protected]> On Behalf Of John Dobbins via Tech-talk
Sent: Thursday, June 6, 2024 10:56 AM
Subject: ADSpinnaker, BlackfkyS 161S7M Not enough available memory to allocate buffers for streaming
I have built, base-7.0.6,  areaDetectorR3-13 with ADSpinnaker master on Alma 9. I am using a FLIR BlackflyS 161S7M USB camera. This is large, 5320x3032 pixels.
The camera is detected but I get a "Not enough available memory to allocate buffers for streaming" error.
In ADSpinnakerConfig I have set numSPBuffer to minimum  = 10 (?)
# ADSpinnakerConfig(const char *portName, const char *cameraId, int numSPBuffers,
#                   size_t maxMemory, int priority, int stackSize)
ADSpinnakerConfig("SP1", 22671882, 10, 0, 0,0)
The host computer has 16G, 13.7 G free,
Ideas?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
www.chess.cornell.edu
[root@lnx615 iocSpinnaker]# ../../bin/linux-x86_64/spinnakerApp st.cmd.BlackflyS_161S7M
< envPaths
epicsEnvSet("IOC","iocSpinnaker")
epicsEnvSet("TOP","/nfs/chess/epics/det/support_flir/areaDetector-R3-13/ADSpinnaker/iocs/spinnakerIOC")
epicsEnvSet("ADSPINNAKER","/nfs/chess/epics/det/support_flir/areaDetector-R3-13/ADSpinnaker/iocs/spinnakerIOC/../..")
epicsEnvSet("SUPPORT","/nfs/chess/epics/det/support_flir")
epicsEnvSet("ASYN","/nfs/chess/epics/det/support_flir/asyn-R4-45")
epicsEnvSet("AREA_DETECTOR","/nfs/chess/epics/det/support_flir/areaDetector-R3-13")
epicsEnvSet("ADSUPPORT","/nfs/chess/epics/det/support_flir/areaDetector-R3-13/ADSupport")
epicsEnvSet("ADCORE","/nfs/chess/epics/det/support_flir/areaDetector-R3-13/ADCore")
epicsEnvSet("AUTOSAVE","/nfs/chess/epics/det/support_flir/autosave-R5-11")
epicsEnvSet("BUSY","/nfs/chess/epics/det/support_flir/busy-R1-7-4")
epicsEnvSet("CALC","/nfs/chess/epics/det/support_flir/calc-R3-7-5")
epicsEnvSet("SNCSEQ","/nfs/chess/epics/det/support_flir/seq-R2-2-9")
epicsEnvSet("SSCAN","/nfs/chess/epics/det/support_flir/sscan-R2-11-5")
epicsEnvSet("DEVIOCSTATS","/nfs/chess/epics/det/support_flir/iocStats-3-1-16")
epicsEnvSet("EPICS_BASE","/nfs/chess/epics/det/base-7.0.6")
epicsEnvSet("ADGENICAM","/nfs/chess/epics/det/support_flir/areaDetector-R3-13/ADGenICam")
errlogInit(20000)
dbLoadDatabase("/nfs/chess/epics/det/support_flir/areaDetector-R3-13/ADSpinnaker/iocs/spinnakerIOC/dbd/spinnakerApp.dbd")
spinnakerApp_registerRecordDeviceDriver(pdbbase)
# Use this line for a specific camera by serial number, in this case a BlackFlyS GigE
epicsEnvSet("CAMERA_ID", "22671882")
epicsEnvSet("GENICAM_DB_FILE", "/nfs/chess/epics/det/support_flir/areaDetector-R3-13/ADGenICam/db/FLIR_BFS_U3_161S7M.template")
< st.cmd.base
# Prefix for all records
epicsEnvSet("PREFIX", "13SP1:")
# The port name for the detector
epicsEnvSet("PORT",   "SP1")
# Really large queue so we can stream to disk at full camera speed
epicsEnvSet("QSIZE",  "2000")
# The maximim image width; used for row profiles in the NDPluginStats plugin
epicsEnvSet("XSIZE",  "2048")
# The maximim image height; used for column profiles in the NDPluginStats plugin
epicsEnvSet("YSIZE",  "2048")
# The maximum number of time series points in the NDPluginStats plugin
epicsEnvSet("NCHANS", "2048")
# The maximum number of frames buffered in the NDPluginCircularBuff plugin
epicsEnvSet("CBUFFS", "500")
# The search path for database files
# This is for Windows
epicsEnvSet("EPICS_DB_INCLUDE_PATH", "/nfs/chess/epics/det/support_flir/areaDetector-R3-13/ADCore/db;/nfs/chess/epics/det/support_flir/areaDetector-R3-13/ADGenICam/db;/nfs/chess/epics/det/support_flir/areaDetector-R3-13/ADSpinnaker/iocs/spinnakerIOC/../../db")
# This is for Linux
#epicsEnvSet("EPICS_DB_INCLUDE_PATH", "$(ADCORE)/db:$(ADGENICAM)/db:$(ADSPINNAKER)/db")
# Define NELEMENTS to be enough for a 5320x3032 (color) image
epicsEnvSet("NELEMENTS", "16130240")
2024/06/06 11:46:16.990 ADSpinnaker::connectCamera exception Spinnaker: Not enough available memory to allocate buffers for streaming. [-1016]
2024/06/06 11:46:16.990 ADSpinnaker:ADSpinnaker:  camera connection failed (3)
Number of cameras detected: 1
Camera 0
Device Vendor Name   (DeviceVendorName):FLIR
Device Model Name (DeviceModelName):Blackfly S BFS-U3-161S7M
Device Serial Number (DeviceSerialNumber):22671882
Device Version (DeviceVersion):2210.0.657.0
Device Type (DeviceType):USB3Vision
ADSpinnaker, BlackfkyS 161S7M Not enough available memory to allocate buffers for streaming John Dobbins via Tech-talk
Re: ADSpinnaker, BlackfkyS 161S7M Not enough available memory to allocate buffers for streaming John Dobbins via Tech-talk
Prev: RE: ADSpinnaker, BlackfkyS 161S7M Not enough available memory to allocate buffers for streaming Mark Rivers via Tech-talk
Next: What is the use case of org.phoebus.pv.PV.onAccessRightsEvent().subscribe() Wang, Lin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: RE: ADSpinnaker, BlackfkyS 161S7M Not enough available memory to allocate buffers for streaming Mark Rivers via Tech-talk
