1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Strange problem with EPICS areaDetector
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Jörn Dreyer <[email protected]>
Date: Wed, 19 Jun 2024 21:26:07 -0700
Hi Jörn,
On 6/19/24 05:47, Jörn Dreyer via Tech-talk wrote:
Hi Ralph,
after some more thinking and investigation, I found a more propper fix for the problem. If one adds the following two lines to
base/configure/os/CONFIG_SITE.linux-x86_64.UnixCommon
CFLAGS += -D_FORTIFY_SOURCE=2
CXXFLAGS += -D_FORTIFY_SOURCE=2
the code gets compiled with the old setting of _FORTIFY_SOURCE. Thats only a temporary fix of course. Clearly the code should be fixed for this errors.
I think this is reasonable.  I have an unpleasant suspicion that
we will be seeing with these "errors" for some time.
It took me awhile to understand that:
*** buffer overflow detected ***: terminated
should actually be understood as "buffer overflow predicted".
And this is in all likelihood a false positive.
If you can, it would be helpful if you could gather some more
information to help us reproduce this fault.  Either by finding
a reduced test case which triggers the fault, or in probing further
with debug prints.  (As far as I can tell, the extra information
used by the fortify checks in not available to the debugger)
The stack trace you shows that access is to a ENUM or MENU field
of an aiRecord.  Which field?
The trace points to the strncpy() at dbAccess.c:192 .
(which interestingly seems to be compiled into a plain strcpy() )
https://urldefense.us/v3/__https://github.com/epics-base/epics-base/blob/772c10d904c2c149ce2154996091858514f27265/modules/database/src/ioc/db/dbAccess.c*L192__;Iw!!G_uCfscf7eWS!Yp-ntUckX3N6O8iHjWlGFPCp1L9RPDJG24HtOKaNMNroby7MnOeAdw-CqP-1vx-kISxEFyPDM0pgiaBGES1Dz6LGIw$
Could you try applying the attached patch, which adds some debug prints?
I see something like the following.  All of the 'f's mean that GCC
is unable to track the sizes of the objects involved.  I also don't
see a fault.
X test.LINR ptemp=ffffffffffffffff,ffffffffffffffff papChoice=ffffffffffffffff,ffffffffffffffff i=0
diff --git a/modules/database/src/ioc/db/dbAccess.c b/modules/database/src/ioc/db/dbAccess.c
index c9d39c57c..1b55aabbf 100644
--- a/modules/database/src/ioc/db/dbAccess.c
+++ b/modules/database/src/ioc/db/dbAccess.c
@@ -191,6 +191,13 @@ choice_common:
                     for (i=0; i<no_str; i++) {
                         if(papChoice[i]==NULL) *ptemp=0;
                         else {
+                            fprintf(stderr, "X %s.%s ptemp=%zx,%zx papChoice=%zx,%zx i=%u\n",
+                                    paddr->precord->name, paddr->pfldDes->name,
+                                    __builtin_dynamic_object_size(ptemp, 0),
+                                    __builtin_dynamic_object_size(ptemp, 1),
+                                    __builtin_dynamic_object_size(papChoice, 0),
+                                    __builtin_dynamic_object_size(papChoice, 1),
+                                    i);
                             strncpy(ptemp,papChoice[i],
                                 sizeof(pdbr_enumStrs->strs[0]));
                             *(ptemp+sizeof(pdbr_enumStrs->strs[0])-1) = 0;
Re: Strange problem with EPICS areaDetector Michael Davidsaver via Tech-talk
Strange problem with EPICS areaDetector Jörn Dreyer via Tech-talk
Re: Strange problem with EPICS areaDetector Ralph Lange via Tech-talk
Re: Strange problem with EPICS areaDetector Jörn Dreyer via Tech-talk
Prev: Re: IOC connection problem Johnson, Andrew N. via Tech-talk
Next: Re: Strange problem with EPICS areaDetector Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: Strange problem with EPICS areaDetector Jörn Dreyer via Tech-talk
