1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: IOC connection problem
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 20 Jun 2024 09:59:21 +0200
Weird.
The iptables fix that Andrew mentioned will make any incoming CA nameres request message that is sent to 164.54.160.193 appear as if it was sent to 164.54.160.255 - if that is what the clients use, that iptables fix wouldn't touch the message.
Still, the effect that only the first IOC started on 13idd gets the nameres messages matches the behavior when clients send them to unicast 164.54.160.193.
Netmask configuration seems right.
That "No route to host" message is unusual. Are the route entries on 13idd the same as on the other boxes?
The next step could be using wireshark on both ends, verifying name resolution request and reply messages on client and server machines.
Good luck,
~Ralph
IOC connection problem Mark Rivers via Tech-talk
Prev: Re: Strange problem with EPICS areaDetector Timo Korhonen via Tech-talk
Next: Re: IOC connection problem Gerrit Kühn via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: IOC connection problem Johnson, Andrew N. via Tech-talk
