1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: [EXTERNAL] IOC connection problem
To: "[email protected]" <[email protected]>, "Hartman, Steven" <[email protected]>
Date: Thu, 20 Jun 2024 14:51:10 +0000
Hi Steve,
You were correct, we just figured out the firewall was running, we neglected to disable it on this machine.
As I said in a recent post, I don't think there is an easy way to run the firewall on a machine with multiple IOCs, since the subsequent IOCs need random ports to be opened for CA.
From: Tech-talk <[email protected]> on behalf of Hartman, Steven via Tech-talk <[email protected]>
Sent: Thursday, June 20, 2024 8:57 AM
To: [email protected] <[email protected]>
I interpret the error message as indicating that the CA name search worked correctly. “caget 13IDD:m1” resolved to 3idd.cars.aps.anl.gov:46799 but the client was not able to connect to the TCP socket. I suspect a firewall blocking the connection, or, less likely, a messed up routing table.
Steven Hartman
[email protected]
On Jun 19, 2024, at 6:45 PM, Mark Rivers via Tech-talk <[email protected]> wrote:
Folks,
I have a number of Linux machines that each run multiple IOCs.  The IOC and clients are all on a single public subnet, 164.54.160.*.  There is also a private subnet that some Linux machines and many devices are connected to, 10.54.160.*.
On the Linux machines I have set the following so that CA searches are only on the public network.  This prevents the warnings about multiple IOCs have the same PV.
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_CA_ADDR_LIST=164.54.160.255
This is working fine for all Linux machines except one, called 13idd.  When I run multiple IOCs on 13idd I observe the following:
  • I can reach all IOCs from clients running locally on 13idd
  • From other machines I can reach the PVs on the first IOC started on 13idd.
  • From other machines when trying to reach PVs on other IOCs on 13idd I get the following error:
[epics@13bmd ~]$ /corvette/usr/local/epics/base/bin/linux-x86_64/caget 13IDD:m1
CAC: Unable to connect because "No route to host"
CA.Client.Exception...............................................
    Warning: "Virtual circuit disconnect"
    Context: "13idd.cars.aps.anl.gov:46799"
    Source File: ../cac.cpp line 1237
    Current Time: Wed Jun 19 2024 17:37:31.591554930
Channel connect timed out: '13IDD:m1' not found.
The message about “No route to host” happens immediately.
That machine is not configured differently from the others, as far as I have been able to tell.
This is the configuration of the 2 NICs on 13idd:
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.54.160.173  netmask 255.255.255.0  broadcast 10.54.160.255
        inet6 fe80::42a6:b7ff:feb4:69ac  prefixlen 64  scopeid 0x20<link>
        ether 40:a6:b7:b4:69:ac  txqueuelen 1000  (Ethernet)
        RX packets 701064543  bytes 258403234658 (240.6 GiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 82557039  bytes 7943801957 (7.3 GiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 164.54.160.193  netmask 255.255.255.0  broadcast 164.54.160.255
        inet6 fe80::42a6:b7ff:feb4:69ad  prefixlen 64  scopeid 0x20<link>
        ether 40:a6:b7:b4:69:ad  txqueuelen 1000  (Ethernet)
        RX packets 28919766  bytes 3450612626 (3.2 GiB)
        TX packets 1894585  bytes 1421681130 (1.3 GiB)
This is the output of epicsPrtEnvParams for the second IOC started on 13idd:
epics> epicsPrtEnvParams
EPICS_CA_ADDR_LIST: 164.54.160.255
EPICS_CA_CONN_TMO: 30.0
EPICS_CA_AUTO_ADDR_LIST: NO
EPICS_CA_REPEATER_PORT: 5065
EPICS_CA_SERVER_PORT: 5064
EPICS_CA_MAX_ARRAY_BYTES: 16384
EPICS_CA_AUTO_ARRAY_BYTES: YES
EPICS_CA_MAX_SEARCH_PERIOD: 300.0
EPICS_CA_NAME_SERVERS is undefined
EPICS_CA_MCAST_TTL: 1
EPICS_CAS_INTF_ADDR_LIST is undefined
EPICS_CAS_IGNORE_ADDR_LIST is undefined
EPICS_CAS_AUTO_BEACON_ADDR_LIST is undefined
EPICS_CAS_BEACON_ADDR_LIST is undefined
EPICS_CAS_SERVER_PORT is undefined
EPICS_CA_BEACON_PERIOD: 15.0
EPICS_CAS_BEACON_PERIOD is undefined
EPICS_CAS_BEACON_PORT is undefined
EPICS_BUILD_COMPILER_CLASS: gcc
EPICS_BUILD_OS_CLASS: Linux
EPICS_BUILD_TARGET_ARCH: linux-x86_64
EPICS_TZ: CST6CDT,M3.2.0/2,M11.1.0/2
EPICS_TS_NTP_INET is undefined
EPICS_IOC_IGNORE_SERVERS is undefined
EPICS_IOC_LOG_PORT: 7004
EPICS_IOC_LOG_INET is undefined
EPICS_IOC_LOG_FILE_LIMIT: 1000000
EPICS_IOC_LOG_FILE_NAME is undefined
EPICS_IOC_LOG_FILE_COMMAND is undefined
IOCSH_PS1: epics>
IOCSH_HISTSIZE: 50
IOCSH_HISTEDIT_DISABLE is undefined
Any idea what could cause this problem?
Re: [EXTERNAL] IOC connection problem Hartman, Steven via Tech-talk
IOC connection problem Mark Rivers via Tech-talk
Prev: Re: [EXTERNAL] IOC connection problem Hartman, Steven via Tech-talk
Next: Re: [EXTERNAL] IOC connection problem Hartman, Steven via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
