1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: mbbo fields don't match db definitions ???
To: John Dobbins <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 21 Jun 2024 21:17:43 +0000
John,
What you are seeing is completely normal.
The template file is created by the Python script using the camera’s XML file.  That XML file contains all possible choices for each enum.  However, not all of those choices are necessarily available at run time, depending on the camera state.  The enum choices in the record at run-time are dynamic, based on which choices are actually available for the current camera configuration.
Note that with older OPIs like medm you will need to close and re-open the window to see the new enum choices. On newer OPIs like Phoebus the enum choices update in the display when they are changed without needing to close and re-open the window.
From: Tech-talk <[email protected]> On Behalf Of John Dobbins via Tech-talk
Sent: Friday, June 21, 2024 4:10 PM
To: [email protected]
Subject: mbbo fields don't match db definitions ???
All,
I am using a FLIR camera with base-7.0.6, areaDetector-R3-13, ADGeniCam-R1-9, ADSpinnake-R3-5 on Alma 9.
This IOC has been running normally but after a restart of the IOC I am seeing a strange problem I have not encountered before. On start-up the IOC loads an mmbo record from FLIR_BFS_U3_161S7M.template but the fields in the instantiated record don't match the database file. [ this doesn't appear to be the only affected record ]
The instantiated record has 13 states where I expect 14. The first state has been lost and all the others are shifted down one with respect to the definition in the template file.
I could imagine the record being over-written later by another db file. I don't see how that would come about when it was ok previously. Is there a way to tell if this is happening?
Any thoughts,
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
www.chess.cornell.edu
dbLoadRecords("/nfs/chess/epics/det/support_flir/areaDetector-R3-13/ADGenICam/db/FLIR_BFS_U3_161S7M.template", "P=BFS1:,R=cam1:,PORT=SP1")
epics> dbpr BFS1:cam1:GC_TriggerSource 4        [0/376]
ACKS: NO_ALARM      ACKT: YES           AMSG:               ASG :
ASP : PTR (nil)     BKLNK: ELL 0 [(nil) .. (nil)]           BKPT: 00
COSV: NO_ALARM      DESC:               DISA: 0             DISP: 0
DISS: NO_ALARM      DISV: 1             DOL : CONSTANT 31   DPVT: PTR 0x53c4dc0
DSET: PTR 0x7f9ca58af220                DTYP: asynInt32     EIST: Counter1Start
EISV: NO_ALARM      EIVL: 0xd           ELST: LogicBlock0   ELSV: NO_ALARM
ELVL: 0x14          EVNT:               FFST:               FFSV: NO_ALARM
FFVL: 0x0           FLNK: CONSTANT      FRST: UserOutput1   FRSV: NO_ALARM
FRVL: 0x5           FTST:               FTSV: NO_ALARM      FTVL: 0x0
FVST: UserOutput2   FVSV: NO_ALARM      FVVL: 0x6
IVOA: Continue normally                 IVOV: 0             LALM: 0
LCNT: 0             LSET: PTR 0x45da5d0 MASK: 4294967295
MLIS: ELL 0 [(nil) .. (nil)]            MLOK: a0 51 71 04 00 00 00 00
MLST: 0             NAME: BFS1:cam1:GC_TriggerSource        NAMSG:
NIST: Counter0End   NISV: NO_ALARM      NIVL: 0x10          NOBT: 0
NSEV: NO_ALARM      NSTA: NO_ALARM      OLDSIMM: NO         OMSL: supervisory
ONST: Line2         ONSV: NO_ALARM      ONVL: 0x2           ORAW: 0
ORBV: 0             OUT : INST_IO @asyn(SP1,0,1)GC_E_TriggerSource
PACT: 0             PHAS: 0             PINI: NO            PPN : PTR (nil)
PPNR: PTR (nil)     PRIO: LOW           PROC: 0             PUTF: 0
RBV : 0             RDES: PTR 0x22fcdb0 RPRO: 0
RSET: PTR 0x7f9ca571d260                RVAL: 0             SCAN: Passive
SDEF: 1             SDIS: CONSTANT      SDLY: -1            SEVR: NO_ALARM
SHFT: 0             SIML: CONSTANT      SIMM: NO            SIMPVT: PTR (nil)
SIMS: NO_ALARM      SIOL: CONSTANT      SPVT: PTR (nil)     SSCN: <nil>
STAT: NO_ALARM      SVST: Counter0Start SVSV: NO_ALARM      SVVL: 0xc
SXST: UserOutput3   SXSV: NO_ALARM      SXVL: 0x7           TEST: Counter1End
TESV: NO_ALARM      TEVL: 0x11          THST: UserOutput0   THSV: NO_ALARM
THVL: 0x4           TIME: 2024-06-21 15:16:03.150013012     TPRO: 0
TSE : 0             TSEL: CONSTANT      TTST:               TTSV: NO_ALARM
TTVL: 0x0           TVST: LogicBlock1   TVSV: NO_ALARM      TVVL: 0x15
TWST: Line3         TWSV: NO_ALARM      TWVL: 0x3           UDF : 0
UDFS: INVALID       UNSV: NO_ALARM      UTAG: 0             VAL : 0
ZRST: Line0         ZRSV: NO_ALARM      ZRVL: 0x0
record(mbbo, "$(P)$(R)GC_TriggerSource") {
  field(DTYP, "asynInt32")
  field(OUT,  "@asyn($(PORT),$(ADDR=0),$(TIMEOUT=1))GC_E_TriggerSource")
  field(DOL,  "31")
  field(ZRST, "Software")
  field(ZRVL, "31")
  field(ONST, "Line0")
  field(ONVL, "0")
  field(TWST, "Line1")
  field(TWVL, "1")
  field(THST, "Line2")
  field(THVL, "2")
  field(FRST, "Line3")
  field(FRVL, "3")
  field(FVST, "UserOutput0")
  field(FVVL, "4")
  field(SXST, "UserOutput1")
  field(SXVL, "5")
  field(SVST, "UserOutput2")
  field(SVVL, "6")
  field(EIST, "UserOutput3")
  field(EIVL, "7")
  field(NIST, "Counter0Start")
  field(NIVL, "12")
  field(TEST, "Counter1Start")
  field(TEVL, "13")
  field(ELST, "Counter0End")
  field(ELVL, "16")
  field(TVST, "Counter1End")
  field(TVVL, "17")
  field(TTST, "LogicBlock0")
  field(TTVL, "20")
  field(FTST, "LogicBlock1")
  field(FTVL, "21")
  field(DISA, "0")
Re: mbbo fields don't match db definitions ??? John Dobbins via Tech-talk
Prev: mbbo fields don't match db definitions ??? John Dobbins via Tech-talk
Next: Re: mbbo fields don't match db definitions ??? John Dobbins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
