1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: compatibility of dotnet package with EPICS 7.0.8
From: Tiziano Niero via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 24 Jun 2024 08:40:51 +0000
Dear sirs,
our customer ask for an EPICS server compatible with 3.15.9 and 7.0.8 versions. We are developing our controller in C#. Is your library at https://www.nuget.org/packages/ChannelAccess/ compatible with clients using these versions?
In any case is it the latest one or there are other available versions?
Many thanks for the response.
Tiziano Niero
Head of Control Software Department
EIE GROUP Srl
via Torino, 151/A - 30172 Mestre-Venezia
tel. +39 041 5317906   fax +39 041 5317757
email tniero at eie.it
EIE GROUP is an International EPCC Company, specialized in Management & Contracting, Engineering & Design and Production & Services. It operates globally in areas such as Astronomy, Astrophysics, Big Science , Civil Infrastructures, Aerospace, large scientific technological facilities and renewable plants.
For more information visit www.eie.it
Ai sensi del D.Lgs.196/2003 si precisa che le informazioni contenute in questo messaggio sono riservate ed a uso esclusivo del destinatario. Qualora il messaggio in parola Le fosse pervenuto per errore, La preghiamo di eliminarlo senza copiarlo e di non inoltrarlo a terzi dandocene gentilmente comunicazione. Grazie. This message, for the law 196/2003, may contain confidential and/or privileged information. If you are not the addressee or authorized to receive this for the addressee, you must not use, copy, disclose or take any action based on this message or any information herein. If you have received this message in error, please advise the sender immediately by reply e-mail and delete this message. Thank you for your cooperation.
JPEG image
Prev: Re: mbbo fields don't match db definitions ??? John Dobbins via Tech-talk
Next: Driver for Eiger1 with SIMPLON 1.8.0 Rong Huang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: RE: mbbo fields don't match db definitions ??? Mark Rivers via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
