1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Guaranteeing access to consistent state in asyn-backed waveforms
From: Érico Nogueira Rolim via Tech-talk <[email protected]>
Date: Fri, 5 Jul 2024 17:46:30 +0000
Hi, folks!
I have an asynPortDriver with array parameters and multiple channels.
For all of these, I use aai records with "I/O Intr" SCAN. For one of
these parameters, I run doCallbacksInt32Array() in a loop, doing it for
each channel in order.
Afterwards, I'd like to feed these resulting waveforms into an aSub
record, making sure I use the updated values for all of them. I'm
currently using this same aSub record for calculations with scalar
records as well, which I can make sure are up to date by using PP input
links [1]; this takes advantage of the default readInt32()
implementation. However, I would like to avoid using PP input links for
the arrays, since it would require implementing readInt32Array(), and
using up memory for the arrays inside the driver.
If I use a CP input link for the last channel, can that guarantee that
the records for all previous channels have already been updated as well?
> From what I understand the callback queue is per record (but there also
isn't buffering for waveform PVs... does that mean that a record has
already been updated when doCallbacksInt32Array() returns?). I can't use
CP for all input links, which would guarantee an eventually correct
value, but would also mean the aSub could have wrong values, calculated
with inconsistent data, temporarily.
One possible way I thought of, though IMO it would be quite messy and
hard to maintain, would be to have a FLNK from each aai record to add 1
to a counter, which, when it reaches the number of channels, triggers
the aSub record; I'd rather avoid that.
[1]
https://urldefense.us/v3/__https://github.com/lnls-dig/afc-epics-ioc/blob/7f0235987f7bac60787035e1b260c4018a885d55/utcaApp/Db/pos_calc.template*L121__;Iw!!G_uCfscf7eWS!YR9ISOwILEKj4QSRCVmLyVDPAVmyyM7Sg2LDHw2w7zD1JnBmcyWR9XvbXoDxpzXnxlEIVIeXcOxPmqjG34yd-ugayH0$
Cheers,
Érico
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Guaranteeing access to consistent state in asyn-backed waveforms Mark Rivers via Tech-talk
Prev: Re: something wrong when run xspress3 autocalibration John Dobbins via Tech-talk
Next: Re: Guaranteeing access to consistent state in asyn-backed waveforms Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
