1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: ADURL failing to open specific URL
From: "Heesterman, Peter via Tech-talk" <[email protected]>
Date: Wed, 17 Jul 2024 16:03:54 +0000
Hi Marco,
I’ll try to help if I can.
I’m not familiar with Hikivision cameras, and I’ve never tested the module with one.
Questions:
Do you get any image frames at all, using ADURL?
Are you able to use a web browser to view the camera? Does it re-direct if you do so?
Does the camera operate in single-frame mode (you have to press F5 in a web browser to get another image) or does it operate in streaming mode?
Cheers,
Peter.
This message contains information that may be privileged or confidential and is the property of the Capgemini Group. It is intended only for the person to whom it is addressed. If you are not the intended recipient, you are not authorized to read, print, retain, copy, disseminate, distribute, or use this message or any part thereof. If you receive this message in error, please notify the sender immediately and delete all copies of this message.
Prev: Re: ADURL failing to open specific URL Ralph Lange via Tech-talk
Next: Re: Channel Finder Recsync Server issue Sandeep Kumar Malu - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: Phoebus and React Automation Studio comparison Kuldeep Joshi via Tech-talk
