1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: dbGetField AI.DPVT
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Dave Bracey <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 22 Jul 2024 21:27:20 +0000
When you do a put to an ai.VAL field of a record that has device support connected to it, you're mostly just triggering the record to process. That will call the device support, which should perform an I/O operation that will update the VAL field.
Many IOC applications use ai (and ao) records just as places to hold a double value that can be written to and read from by other local records or over the network. In that case they're relying on being able to write to the VAL field.
As John Sinclair replied, the DPVT field normally holds a pointer to an internal structure that is defined by the specific device support being used for that record; you would only be able to store stuff in it if you wrote that device support code, and in that case you wouldn't use dbGetField() to access it anyway.
- Andrew
On 7/22/24, 4:06PM, "Dave Bracey" <[email protected]> wrote:
I find that I can PVPUT (cmd line) to an AI, and I feel that this is probably not a good thing. It seems to me that the hardware should be the only thing that changes the value of an AI PV. Without going into detail, I was going to use DPVT
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Without going into detail, I was going to use DPVT as a side-channel to ensure that only the hardware can put to the AI.
Date: Monday, July 22, 2024 at 3:48
PM
To: Dave Bracey <[email protected]>, [email protected] <[email protected]>
[EXTERNAL] – This message is from an external sender
Hi Dave,
There's a reason the DPVT field is called "Device Private" — it's not intended to be accessible from outside the device support code which owns it. Think of it like a C++ private: class-member access specifier. That doesn't mean it's impossible for other software running inside the IOC to get to it, but dbGetField() can't do it by design.
What's the higher-level problem that you're trying to solve which seems to require this? Please describe that to the list and we can try to offer other approaches that wouldn't require you to break the encapsulation.
- Andrew
On 7/22/24, 2:47PM, "Tech-talk" <[email protected]> wrote:
I want to use dbGetField to get the value of the DPVT field of an AI record.  Does this work?  What field type would I specify?
I tried with DBR_LONG and it didn’t like that.  I used the field_type returned from dbNameToAddr (17) and it didn’t like that.
Dave Bracey
Fermilab AD Instrumentation
dbGetField AI.DPVT Dave Bracey via Tech-talk
Re: dbGetField AI.DPVT Johnson, Andrew N. via Tech-talk
Re: dbGetField AI.DPVT Dave Bracey via Tech-talk
Prev: Re: dbGetField AI.DPVT Charter via Tech-talk
Next: Re: dbGetField AI.DPVT Érico Nogueira Rolim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
