1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Re: IOC with Normative Types
From: Dave Bracey via Tech-talk <tech-talk at aps.anl.gov>
To: "Kasemir, Kay" <kasemirk at ornl.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 25 Jul 2024 15:29:22 +0000
If I generated an IOC with makeBaseApp.pl, how would I add a PV which is an NTScalar?  What record type would map to that?  How would I add device support to service the record?
I’m not finding any substantive documentation.  I feel I must not be understanding how this works.  Do the existing record types map to NT PV’s?
I’m expecting to see a new set of record types for the NT types, and to specify those in an IOC’s DB.  Is this not the case?
Date: Thursday, July 25, 2024 at 10:01
AM
To: Dave Bracey <dbracey at fnal.gov>, tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
[EXTERNAL] – This message is from an external sender
> How does one build an IOC that integrates the NT types?
In short, you do almost nothing.
Instead of “softIoc” you use “softIocPVA” to run your database.
Instead of “caget” you can then use “pvget”, and instead of the Channel Access DBR.. types you get NT.
> I’m having a hard time finding any such material.
See PV Access intro on https://controlssoftware.sns.ornl.gov/training/2022_USPAS/,
or watch the video from 2022 EPICS meeting,
https://indico.cern.ch/event/1173788/page/25739-workshops-and-trainings,
https://indico.cern.ch/event/1173788/page/27020-video-material
If you build your own IOC, check the output of “makeBaseApp.pl -t example” for the crucial Makefile section to add PVA, as shown around 28 minutes into the video.
Kay
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Dave Bracey via Tech-talk <tech-talk at aps.anl.gov>
Date: Thursday, July 25, 2024 at 10:50
AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: [EXTERNAL] IOC with Normative Types
Are there any guides or examples -  i.e. a “Hello World” project anywhere?
Dave Bracey – Fermilab Accel Dept Instrumentation
Re: IOC with Normative Types Kasemir, Kay via Tech-talk
Re: IOC with Normative Types Pierrick M Hanlet via Tech-talk
Re: IOC with Normative Types Michael Davidsaver via Tech-talk
IOC with Normative Types Dave Bracey via Tech-talk
Prev: Re: IOC with Normative Types Kasemir, Kay via Tech-talk
Next: Re: IOC with Normative Types Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
