1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Accessing NTAttribute of an NTNDArray from Phoebus?
From: "Feister, Scott via Tech-talk" <[email protected]>
Date: Fri, 2 Aug 2024 01:59:52 +0000
Hi EPICS users,
I’m using Phoebus/CS-Studio to work with a data stream of PVAccess NTNDArray. The NTNDArray normative type has an “attribute” element, which is an array of NTAttribute[]. Does anyone know if I can access these attributes from within Phoebus/CS-Studio? Thanks!
The closest I’ve gotten so far is to build a Probe:
pva://MYIOC:myarray/attribute[2]
Which would pull out the second attribute and show text that includes details; however, this doesn’t give direct access to the value field of the attribute itself, which I’d like to show in a Display Panel.
Thanks!
Scott
Prev: Re: P4P/PVXS repository moves Michael Davidsaver via Tech-talk
Next: Install issues for labCA (channel access interface for matlab) Rajan Mistry - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: RE: areaDetector driver unlock/lock for doCallbacksGenericPointer() Mark Rivers via Tech-talk
