1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: Long string PV access in CA client.
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "Li, Ji" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 9 Aug 2024 19:13:09 +0000
You need to use “pvname.VAL$”. The IOC will then use char[] for the value instead of the ‘string’.
For type and count, you can use the values that you get in the connect callback.
Should be a char[] type with size based on the text length, so the type to read needs to be one of the DBR…CHAR types with that count.
From: Tech-talk <[email protected]> on behalf of Li, Ji via Tech-talk <[email protected]>
Date: Friday, August 9, 2024 at 2:51
PM
To: [email protected] <[email protected]>
Subject: [EXTERNAL] Long string PV access in CA client.
I have a CA client that monitors several PVs through subscription (ca_create_subscription), gets values by copying from corresponding eha.dbr fields, and puts values to some PVs. It works well with all PVs except for long string ones, as it behaves like caget command withou -S option, i.e., it can only access the first 40 characters of the PV values. For it to work properly with long strings, how do I:
  • specify a PV. Should I use pvname or pvname.VAL$?
  • subscribe. What type and count value should be used for the function call?
  • get. Is the returned value stored in eha.dbr?
  • put. How to write a long string to a (lsi) PV?
Best,
-Ji
Long string PV access in CA client. Li, Ji via Tech-talk
Prev: Long string PV access in CA client. Li, Ji via Tech-talk
Next: measComp E-TC alarm IOC init error 106 Rong Huang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
