1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: measComp E-TC alarm IOC init error 106
To: [email protected]
Date: Fri, 9 Aug 2024 18:05:14 -0500
Hello,
I forgot to mention in previous email that Inside ETC.substitutions, I changed binary I/O channel 1-4 to output, and channel 5-8 as inputs:
 # Direction bits on binary I/O
#  VAL 0=input, 1=output
file "$(MEASCOMP)/db/measCompBinaryDir.template"
# RH change 1-4 from In(0) to out(1), and 5-8 from out(1) to In(0)
pattern
{  R,  MASK,  VAL, ADDR}
{Bd1,  0x01,    1,    0}
{Bd2,  0x02,    1,    0}
{Bd3,  0x04,    1,    0}
{Bd4,  0x08,    1,    0}
{Bd5,  0x10,    0,    0}
{Bd6,  0x20,    0,    0}
{Bd7,  0x40,    0,    0}
{Bd8,  0x80,    0,    0}
Rong
On Fri, Aug 9, 2024 at 5:40 PM Rong Huang <[email protected]> wrote:
Hello,
When using measComp-R4-23 for E-TC, and set first two temperature inputs as alarm using Instacal, IOC started with errors complaining "devAsynUInt32Digital::processCallbackOutput process write error"
I am using asyn-R4-44-2, synApps-R6-2-1, base-7.0.8.
Tested temperature channel 1 and 2 with alarm T1 = 30, clear T2=29, both medm "inputs" color-change (green/red) and DIO0, DIO1 voltage outputs (TTL 5.0V) told me that the temperature alarm for both channels is working. Hope this minor error does not affect any instrument function.
Thank you!
Rong
$ ../../bin/linux-x86_64/measCompApp st.cmd
< envPaths
epicsEnvSet("IOC","iocETC")
epicsEnvSet("TOP","/opt/epics/synApps-R6-2-1/support/measComp-R4-3")
epicsEnvSet("SUPPORT","/opt/epics/synApps-R6-2-1/support")
epicsEnvSet("ASYN","/opt/epics/synApps-R6-2-1/support/asyn-R4-44-2")
epicsEnvSet("CALC","/opt/epics/synApps-R6-2-1/support/calc-R3-7-5")
epicsEnvSet("SCALER","/opt/epics/synApps-R6-2-1/support/scaler-4-1")
epicsEnvSet("MCA","/opt/epics/synApps-R6-2-1/support/mca-R7-10")
epicsEnvSet("BUSY","/opt/epics/synApps-R6-2-1/support/busy-R1-7-4")
epicsEnvSet("SSCAN","/opt/epics/synApps-R6-2-1/support/sscan-R2-11-6")
epicsEnvSet("AUTOSAVE","/opt/epics/synApps-R6-2-1/support/autosave-R5-11")
epicsEnvSet("SNCSEQ","/opt/epics/synApps-R6-2-1/support/seq-R2-2-9")
epicsEnvSet("MEASCOMP","/opt/epics/synApps-R6-2-1/support/measComp-R4-3")
epicsEnvSet("EPICS_BASE","/opt/epics/base")
dbLoadDatabase "/opt/epics/synApps-R6-2-1/support/measComp-R4-3/dbd/measCompApp.dbd"
measCompApp_registerRecordDeviceDriver pdbbase
#epicsEnvSet("PREFIX",        "ETC:")
# RH
epicsEnvSet("PREFIX",        "21:D1:")
epicsEnvSet("PORT",          "ETC_1")
#epicsEnvSet("UNIQUE_ID",     "10.54.160.218")
# RH
epicsEnvSet("UNIQUE_ID",     "10.1.17.36")
## Configure port driver
# MultiFunctionConfig((portName,        # The name to give to this asyn port driver
#                      uniqueID,        # For USB the serial number.  For Ethernet the MAC address or IP address.
#                      maxInputPoints,  # Maximum number of input points for waveform digitizer
#                      maxOutputPoints) # Maximum number of output points for waveform generator
MultiFunctionConfig("ETC_1", "10.1.17.36", 1, 1)
#asynSetTraceMask($(PORT), -1, ERROR|FLOW|DRIVER)
dbLoadTemplate("/opt/epics/synApps-R6-2-1/support/measComp-R4-3/db/ETC.substitutions", "P=21:D1:,PORT=ETC_1")
< ../save_restore.cmd
### save_restore setup
# The rest this file does not require modification for standard use, but...
# If you want save_restore to manage its own NFS mount, specify the name and
# IP address of the file server to which save files should be written.
# This currently is supported only on vxWorks.
#save_restoreSet_NFSHost("oxygen", "164.54.52.4")
# Debug-output level
save_restoreSet_Debug(0)
# Ok to save/restore save sets with missing values (no CA connection to PV)?
save_restoreSet_IncompleteSetsOk(1)
# Save dated backup files?
save_restoreSet_DatedBackupFiles(1)
# Number of sequenced backup files to write
save_restoreSet_NumSeqFiles(3)
# Time interval between sequenced backups
save_restoreSet_SeqPeriodInSeconds(300)
# specify where save files should be
set_savefile_path(".", "autosave")
# specify what save files should be restored.  Note these files must be
# in the directory specified in set_savefile_path(), or, if that function
# has not been called, from the directory current when iocInit is invoked
set_pass0_restoreFile("auto_settings.sav")
set_pass1_restoreFile("auto_settings.sav")
# specify directories in which to to search for included request files
# Note cdCommands defines 'startup', but envPaths does not
set_requestfile_path(".",         "")
set_requestfile_path(".",         "autosave")
set_requestfile_path(/opt/epics/synApps-R6-2-1/support/autosave-R5-11, "db")
set_requestfile_path(/opt/epics/synApps-R6-2-1/support/calc-R3-7-5,     "db")
set_requestfile_path(/opt/epics/synApps-R6-2-1/support/scaler-4-1,   "db")
set_requestfile_path(/opt/epics/synApps-R6-2-1/support/sscan-R2-11-6,    "db")
set_requestfile_path(/opt/epics/synApps-R6-2-1/support/measComp-R4-3, "db")
iocInit
Starting iocInit
## EPICS R7.0.8
## Rev. 2024-04-05T14:18-0500
## Rev. Date build date/time:
2024/08/09 17:08:14.163 MultiFunction::writeUInt32Digital Error: Calling ConfigBit, err=106 The specified bit is used for alarm
2024/08/09 17:08:14.163 21:D1:Bd1 devAsynUInt32Digital::processCallbackOutput process write error
2024/08/09 17:08:14.164 21:D1:Bd2 devAsynUInt32Digital::processCallbackOutput process write error
create_monitor_set("auto_settings.req",30,"P=21:D1:")
epics> auto_settings.sav: 72 of 72 PV's connected
Re: measComp E-TC alarm IOC init error 106 Mark Rivers via Tech-talk
measComp E-TC alarm IOC init error 106 Rong Huang via Tech-talk
Prev: measComp E-TC alarm IOC init error 106 Rong Huang via Tech-talk
Next: Re: Difference among SNMP support modules for general SNMP-aware devices Paduan Donadio, Marcio via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Next: Re: measComp E-TC alarm IOC init error 106 Mark Rivers via Tech-talk
