1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: how is envPaths built?
From: William Kirstaedter via Tech-talk <[email protected]>
To: Marco Filho <[email protected]>
Date: Wed, 28 Aug 2024 15:43:36 +0200
Thank you for your email.
you brought me to look at the envPath function in convertRelease.pl as well, and I showed it to my colleague Mike who knows perl very well.
we then discovered that the script just generates the $(IOC) variable from the $(TOP)/iocBoot/iocYOURNAME/ path (in perl its the $cwd variable)
by just removing everything before the last "/". ($ioc =~ s/^.*\///; -> $ioc =~ s/ ^.*\/ / /;)
so, I'll leave my dbLoadDatabase "dbd/test.dbd" hardcoded and not use $(IOC) here.
thanks! :)
William Kirstaedter
PP&B Computer Support Group
Fritz-Haber-Institut Berlin
Am 28.08.24 um 14:02 schrieb Marco Filho:
For some reason my emails aren't going to tech-talk... Re-sending it here
You kinda got me curious to this too.
I found this script segment which seems to be creating envPaths in epics-base/bin/linux-x86_64/convertRelease.pl:
# Generate envPaths file with epicsEnvSet commands for iocsh IOCs.
# Include parentheses anyway in case CEXP users want to use this.
sub envPaths {
    my @includes = grep !m/^ (RULES | TEMPLATE_TOP) $/x, @apps;
    unlink($outfile);
    open(OUT,">$outfile") or die "$! creating $outfile";
    my $ioc = $cwd;
    $ioc =~ s/^.*\///;  # iocname is last component of directory name
    print OUT "epicsEnvSet(\"IOC\",\"$ioc\")\n";
    foreach my $app (@includes) {
        my $iocpath = my $path = $macros{$app};
        $iocpath =~ s/^$root/$iocroot/o if ($opt_t);
        $iocpath =~ s/([\\"])/\\$1/g; # escape back-slashes and double-quotes
        print OUT "epicsEnvSet(\"$app\",\"$iocpath\")\n" if (-d $path);
    close OUT;
I don't know perl but it seems it gets the name from the directory and the directory itself is created from another mechanism from makeBaseApp?
I tried changing the directory name and recompiling and it really changes the IOC variable name in envPaths. I'm not sure where is the part of makeBaseApp that creates the directory though.
From: Tech-talk <[email protected]> on behalf of William Kirstaedter via Tech-talk <[email protected]>
Sent: 28 August 2024 10:38
To: [email protected]
Subject: how is envPaths built?
Hello,
I'd like to know how the envPaths file in the iocBoot Directory is built.
I tried to load the IOC's main dbd file by using the $(IOC) variable
from envPaths, but noticed that it always will contain an "ioc" Prefix
to the actual IOC name, while the dbd file is called just like the IOC name.
for example, if you create a new empty IOC by using "makeBaseApp.pl -t
ioc test" and "makeBaseApp.pl -i -t ioc test":
you get a Makefile in $(TOP)/testApp/src/ that builds a test.dbd
while in iocBoot, envPaths with always have the $(IOC) variable set to
"ioctest".
Just curious,
William Kirstaedter
Attachment: smime.p7s
Description: Kryptografische S/MIME-Signatur
how is envPaths built? William Kirstaedter via Tech-talk
Re: how is envPaths built? Marco Filho via Tech-talk
Prev: Re: how is envPaths built? Ralph Lange via Tech-talk
Next: Re: how is envPaths built? Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: how is envPaths built? Han Lee via Tech-talk
Next: MVME 5500 How to flash the VxWorks bootrom? whitetiger1123 via Tech-talk
