We have this: https://urldefense.us/v3/__http://docs.eao.hawaii.edu/EXTERNAL/MOTOROLA/vxWorksBoot/vxWorksBoot.pdf__;!!G_uCfscf7eWS!aZIZSMHxuGTxDl2v4jGSmTjVf5x5iz_t1EohfSkAB-o0YGWgZV59_z4ssvWtMLYJtmkhicGb5sRK0aVXavDdX4c2kOBq$
which originates from Andrew but has additions and notes from other
people as well (I recognize Craig Walther's handwriting) - and some
specifics that are local to us here of which I'm sure they won't
apply to you, like the name of the boot host to use for this (we're
still running VxWorks 5.5 :) , btw)
Aloha,
Maren Purves
Head of Instrument and Telescope Software
East Asian Observatory / JCMT
On Thu, Aug 29, 2024 at 8:47 PM whitetiger1123 via Tech-talk
<[email protected]> wrote:
> Hello all,
> Currently, we are using the mvme6100 model. However, we heard that it will be discontinued. We would like to secure an additional 5500 or 3300 model for maintenance. However, before purchasing, we would like to make sure that the mvme5500 we have is compatible with vxworks6.9 os.
> I'm trying to copy this link from Tech Talk.
> https://urldefense.us/v3/__https://epics.anl.gov/tech-talk/2004/msg00847.php__;!!G_uCfscf7eWS!aZIZSMHxuGTxDl2v4jGSmTjVf5x5iz_t1EohfSkAB-o0YGWgZV59_z4ssvWtMLYJtmkhicGb5sRK0aVXavDdXyGR0DIW$
> As for the jumper setting, I set the jumper j8 to flash1 as told here.
> Copyright Motorola Inc. 1999-2003, All Rights Reserved
> MOTLoad RTOS Version 2.0, PAL Version 1.1 RM02
> Tue Jul 1 16:34:30 MST 2003
> Warning: Global Environment Variable Area is uninitialized, use gevInit.
> MPU-Int Clock Speed =1000MHz
> MPU-Ext Clock Speed =133MHz
> MPU-Number/Type = 0/MPC7455
> MPU-Int Cache(L2) = 256K, Enabled, L2CR =0xC0000000
> MPU-Ext Cache(L3) = 2MB, Enabled, 200MHz, L3CR=0xDF826000
> Reset/Boot Vector =Flash1
> Local Memory Found =20000000 (&536870912)
> User Download Buffer =005C3000:007C2FFF
> MVME5500> netShow
> Interface EAddress Status Speed Duplex
> /dev/enet0 0001AF0B1BEC Up 100MBS Full
> /dev/enet1 0001AF0B1BED Downp Unknown Unknown
> MVME5500> gevEdit mot-/dev/enet0-cipa
> PReP NVRAM header test failed
> I can’t do anything because of this red line error message.
> Even if I do,
> MVME5500> gevEdit mot-script-boot
> Can you give me any advice?
> I really appreciate it.
> Best & Regards,
> Beag.
- MVME 5500 How to flash the VxWorks bootrom? whitetiger1123 via Tech-talk
RE: MVME 5500 How to flash the VxWorks bootrom? whitetiger1123 via Tech-talk
<2024>
2025
2026
<2024>
2025
2026
