1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: MVME 5500 How to flash the VxWorks bootrom?
From: "Wang, Lin via Tech-talk" <[email protected]>
To: whitetiger1123 <[email protected]>
Date: Fri, 30 Aug 2024 23:09:28 +0800 (GMT+08:00)
Hello Beag,
Typically, the "Boot ROMS" section of "WindRiver/vxworks-6.x/target/config/mv5500/target.ref" file provides info for the bootrom of the BSP including how to flash.
The firmware used to flash the bootrom is called MOTLoad, so looking for a PDF version of "MOTLoad Firmware Package User's Manual" online may help.
I think another thing to consider is whether the MVME5500 you have is the same as the latest MVME5500 product. I remember the 2014 version of MVME5500 upgraded the Ethernet controller from Intel 82544 to Intel 82545, not sure if the current version has any further hardware upgrade.
Lin
-----原始邮件-----
发件人: "whitetiger1123 via Tech-talk" <[email protected]>
发送时间: 2024-08-30 15:48:01 (星期五)
收件人: "[email protected]" <[email protected]>
主题: [SPAM] RE: MVME 5500 How to flash the VxWorks bootrom?
I solved this error and try to set client, server, gateway, subnet ip address.
It was because of “Warning: Global Environment Variable Area is uninitialized, use gevInit.”
I did it gevInit and pressed Y, it changed.
Btw there’s no way how to change subnet IP address mask.
How can I know the command?
I already changed cliend as cipa, server as sipa, gateway as gipa.
Thank you always for your help and advice.
Best and Regards,
Baeg
보낸 사람: whitetiger1123
보낸 날짜: 2024년 8월 30일 금요일 오후 3:46
받는 사람: [email protected]
제목: MVME 5500 How to flash the VxWorks bootrom?
Hello all,
Currently, we are using the mvme6100 model. However, we heard that it will be discontinued. We would like to secure an additional 5500 or 3300 model for maintenance. However, before purchasing, we would like to make sure that the mvme5500 we have is compatible with vxworks6.9 os.
I'm trying to copy this link from Tech Talk.
https://epics.anl.gov/tech-talk/2004/msg00847.php
As for the jumper setting, I set the jumper j8 to flash1 as told here.
Copyright Motorola Inc. 1999-2003, All Rights Reserved
MOTLoad RTOS Version 2.0,  PAL Version 1.1 RM02
Tue Jul 1 16:34:30 MST 2003
MPU-Int Clock Speed =1000MHz
MPU-Ext Clock Speed =133MHz
MPU-Number/Type = 0/MPC7455
MPU-Int Cache(L2) = 256K, Enabled, L2CR =0xC0000000
MPU-Ext Cache(L3) =   2MB, Enabled, 200MHz, L3CR=0xDF826000
Reset/Boot Vector    =Flash1
Local Memory Found   =20000000 (&536870912)
User Download Buffer =005C3000:007C2FFF
MVME5500>  netShow
Interface            EAddress               Status      Speed         Duplex
/dev/enet0       0001AF0B1BEC                 Up        100MBS          Full
/dev/enet1       0001AF0B1BED                Downp       Unknown      Unknown
MVME5500> gevEdit mot-/dev/enet0-cipa
PReP NVRAM header test failed
I can’t do anything because of this red line error message.
Even if I do,
MVME5500> gevEdit mot-script-boot
Can you give me any advice?
I really appreciate it.
Best & Regards,
Beag.
MVME 5500 How to flash the VxWorks bootrom? whitetiger1123 via Tech-talk
RE: MVME 5500 How to flash the VxWorks bootrom? whitetiger1123 via Tech-talk
Prev: Re: MVME 5500 How to flash the VxWorks bootrom? Maren Purves via Tech-talk
Next: RE: Upgrading EPICS base from 3.15.6 to 7.0.x Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
