1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Adding additional fields to be archived in "policies.py"
From: Timo Korhonen via Tech-talk <[email protected]>
To: Gerrit Kühn <[email protected]>
Cc: Michael Davidsaver via Tech-talk <[email protected]>
Date: Mon, 9 Sep 2024 13:35:10 +0000
> when using caget on the commandline. However, when looking into the
> archiver data, .STAT changes from 0 to 1 while .SEVR stays at 0 all the
> time. I would have expected 10 for .STAT and 3 for .SEVR as seen on the
> commandline with caget.
That would have been my expectation as well. The behavior you see does not make sense to me.
Caget/camonitor, as well as pvmonitor behave as I expect.
I have not tried that with AA myself, maybe somebody with more insight could chime in?
But if that does not work, then I guess the only option left would be to add one (or two, if you want separate severity and status) more PVs.
Timo
On 2024-09-09, 12:09, "Gerrit Kühn" <[email protected] <mailto:[email protected]>> wrote:
Am Fri, 6 Sep 2024 10:34:52 +0000
schrieb Timo Korhonen <[email protected] <mailto:[email protected]>>:
> > Maybe the plugin doesn't support this? In that case would could
> > probably fall back on creating an extra channel per device that
> > reflects the error status. Or would the first idea we had (simply
> > adding PVNAME.STAT explicitely to the archiver) work as well?
> In the meantime, until the requested feature is available in the plugin,
> you can of course use your first idea. That should work, albeit with the
> caveats that I mentioned earlier (non-atomicity). Adding an extra
> channel (=record) should not be necessary.
We tried this meanwhile and added .STAT and .SEVR excplicitely to the
archiver. However, I'm not quite sure what to make of the result:
When unplugging the device, we get
.STAT TIMEOUT
.STAT 10
.SEVR INVALID
.SEVR 3
cu
Gerrit
Adding additional fields to be archived in "policies.py" Windsor Tanner via Tech-talk
Re: Adding additional fields to be archived in "policies.py" Michael Davidsaver
Re: Adding additional fields to be archived in "policies.py" Gerrit Kühn
Re: Adding additional fields to be archived in "policies.py" Timo Korhonen via Tech-talk
Re: Adding additional fields to be archived in "policies.py" Gerrit Kühn via Tech-talk
Prev: The teck-talk mailing list seems to be unarchived Shuei YAMADA via Tech-talk
Next: lso record Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: Adding additional fields to be archived in "policies.py" Gerrit Kühn via Tech-talk
Next: OPCUA v0.10: full support for open62541 SDK client Ralph Lange via Tech-talk
