1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Initializing lsi or waveform with long string in 3.15.9
From: "Barrett \(US\), Patrick E via Tech-talk" <[email protected]>
To: "'[email protected]'" <[email protected]>
Date: Tue, 17 Sep 2024 13:46:06 +0000
Hello,
I am trying to initialize (set default value) of either an lsi or waveform record with a string which is 125 characters.  I have tried using the bracket notation in the INP field, but still get syntax error messages during IOC initialization.  Is this initialization method not available in 3.15.9?
The record definition I tried is:
record(lsi, " test")
   field(DTYP, "Soft Channel")
   field(PINI, "YES")
   field(SIZV, "125")
   field(INP, ["XXXOCXXXOCXXXOCOOOO?CCC?CXXXO?XXXO?XXXO?OOOO??????XXXO?XXXO?XXXO?OOOO??????CCC?CCCC?CCCC?C?????CCC?COOOOPO??OPO??OPOOOOOPPPOP"])
Thank you,
Patrick Barrett
Re: Initializing lsi or waveform with long string in 3.15.9 Michael Davidsaver via Tech-talk
Prev: Re: HTTP PUT Request - StreamDevice Zimoch Dirk via Tech-talk
Next: New to EPICS - wants to use motorMotorSim - Python client Guijarro Mathias Charles via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: Warning on Linux kernel < 2.6.31 (Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL) Shuei YAMADA via Tech-talk
Next: Re: Initializing lsi or waveform with long string in 3.15.9 Michael Davidsaver via Tech-talk
