1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: FLIR SpinView on alma 9?
From: Joshua Einstein-Curtis via Tech-talk <[email protected]>
Date: Tue, 24 Sep 2024 11:22:57 -0500
John,
I've had no issues (generally) with it on Arch Linux (Endeavor OS), but using dpkg and the provided install script. It isn't really the "proper" solution as I should have built a PKGBUILD for it, though. But it does install into /opt/spinnaker and and run. The deb files mainly put everything in /opt/spinnaker and /usr/share, with an additional ld.so.conf file for the libraries to be pointed to in /opt/spinnaker. It seemed low risk.
There was an environment variable that I also needed to set for it previously, but it tells you on the command line what the variable is when running from a terminal. I believe they fixed the issue in recent releases on Linux as well.
I will say that I haven't been able to use it to set the camera's default IP address, and had to do that in Windows, though. That was with trying both KDE and XFCE, so I'm not sure if it is a theme issue or a missing binding somewhere.
Josh EC
RadiaSoft LLC
FLIR SpinView on alma 9? John Dobbins via Tech-talk
Prev: Re: archive appliance some PVs no data Michael Davidsaver via Tech-talk
Next: Simple CAN bus over ethernet interface Evans, Richard K. (GRC-H000) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: FLIR SpinView on alma 9? John Dobbins via Tech-talk
Next: Writing XML directly to area detector's NDAttributesFile PV Wolfman, Mark via Tech-talk
